Home -> Forums -> Construction -> Ground work -> COST OF COLUMN PER SFT
Sun Jun 28, 2015Total posts : 2
Ganesh
Ganesh
Topic: COST OF COLUMN PER SFT
Sir Please clear my doubts , I'm just stepping into construction
of my dream house.
From Basement to 30 feet high 3 Floors (Ground + 2 Floors)
RCC and RBC Diffrence ?
Cost of RCC and RBC per SFT?
Which Size and Category of steel is better for 3 story building for RCC and Columns and Beams.?
I heard steel some people are selling cheap one which is refurbished ? how can we differentiate that ?
Cement Type and caustions ?
and any help full information?
thanks
Mon Jun 29, 2015Post  #1
Dear Ganesh
   Use RCC NOT RBC no doubts RCC IS COSTLY, but in column, lintel and beam you can not use RBC, you can only use RBC in slab but RBC LIFE is less as copare to RCC.
  USE MS steel of any of standard factory/ make.
Size of MS steel bars should be according to design and drawing.
Use MS steel of standard make such as TATA and some other IS holding Steel manufacturer.
The cement required for construction should be factory-manufactured from a reputed manufacturer. It must not be from the local plant manufacturer. Care should be taken that the cement is properly packed from the factory, not be hand packed locally. While taking supply of cement manufacturing date, grade and type should be checked. The cement should not be more than six weeks old from the date of manufacturing.
Various Brands of Cement
1. ACC
2. J.K.( Shakti Laxmi)
3. Birla ( Chetak Mehar ,Uttam, Khauraho, Manglam)
4. Shree
5. Prism
6. Dig Vijay
7. Ambuja
8. CCI
9. Vikram
10. Jay Pee Rewa
11. Binani
12. Shri Ultra
13. L. & T.
Various Brands of White Cement
1. J.K.
        2. Birla
Fri Jul 03, 2015Post  #2
Use RCC in columns, Lantel and beams. No RBC. Use any brand of cement, no problem. Pure MS steel id of TATA Tiscon and Kamdhenu 10000, but would be around 10 Rs/kg expensive than the refurnaced.
2681
3289
what is the cost of rolling shutter per sft what guage should br used
Last answer on 8/27/2013 9:57:24 PM. by kiran kumar 3k. Forum started by kiran kumar 3k
4836
2720
2207
Need cost for New construction - 900 SFT
Last answer on 3/4/2015 8:32:16 PM. by JAI PRAKASH. Forum started by Marimuthu
2557
1994
How to select Mason
Last answer on 2/3/2022 11:34:26 PM. by JAI PRAKASH. Forum started by syedwajidali
2087
requirement ofconstruction materiales details per sft
Last answer on 1/5/2022 1:01:21 AM. by S L Gupta (Civil Engg). Forum started by K.S.RAJKUMAR
1682
Temporary Accomodation
Last answer on 9/8/2015 9:27:01 PM. by JAI PRAKASH. Forum started by vijay
2260
m15 cost vs m20 cost
2069
structure
Last answer on 4/21/2014 3:03:37 PM. by S L Gupta (Civil Engg). Forum started by HAMEED
1670
Last answer on 5/3/2016 12:13:14 AM. by JAI PRAKASH. Forum started by sayeedmohsin
2212
6588
wood shelves vs cement shelves
Last answer on 7/3/2020 10:09:54 PM. by JAI PRAKASH. Forum started by uma mahesh
1946
plz Give me 2400 sft /2700 sft Mice front view
Last answer on 11/25/2013 11:55:39 AM. by S L Gupta (Civil Engg). Forum started by progressiveassociates.mirpur
6914
Plan for 3 Story building with 2 Apartments per floor
Last answer on 6/8/2012 11:35:52 PM. by Swati Satija. Forum started by AR
2733
present cost of constuction per sq feet
Last answer on 11/29/2011 3:40:09 PM. by S L Gupta (Civil Engg). Forum started by ajeett
2663
I want to know the cost of this flooring per square feet
Last answer on 8/27/2013 12:29:33 PM. by S L Gupta (Civil Engg). Forum started by b.jaganathan
2995
8160
software
3900
2730
1833
lanterns
3134
false ceiling
2245
about construction
1786
4154
Cement Coba
3076
Water Harvesting System
1676
1758
water tank
2058
1760
1634
Pool construction cost
1994
2738
Regarding roof beam
Fire Stair case
2645
2371
super structure
