Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> COSTING AND STRENGTH OF WALL
Mon Jan 18, 2016Total posts : 5
BYJU
BYJU
Topic: COSTING AND STRENGTH OF WALL
COST OF BUILDING A   GODOWN  SIDE WALL USING 12*8*6 CEMENT SOLID (HYDRAULIC) BRICKS AND BOTH SIDE PLASTERING VS RCC CONCRETE WALL OF 3 INCHES THICKNESS USING 8 MM TORE  - WHICH NEEDS NO PLASTERING. RCC  WILL BE DONE USING 8FT 4 FT SHUTTERS AT BOTH SIDES. WHICH IS MORE STRONGER ?
Tue Jan 19, 2016Post  #1
Dear Byju
             RCC wall is more strong but having 10% costly
Tue Jan 19, 2016Post  #2
BYJU
BYJU
Post subject: COSTING AND STRENGTH OF WALL
THANKS FOR THE REPLY.
SO CAN WE USE WELDED MESH OF SMALLER SIZE AND SAVE ? IS THERE A NEED FOR MORE STRONGER PILLARS OR THE CONVENTIONAL ONE ?
9447033201
Wed Jan 20, 2016Post  #3
       Your question is not clear but as per my under standing you do not want to construct wall but want to make barrier by using welded mesh. Made brick pillar at least 18''x 18'' with coarse sand in cement mortar 1;3.
Sat Jan 23, 2016Post  #4
Pattie Weir
Pattie Weir
Post subject: Gaming
I’m excited to uncover this page. I need to to thank you for ones time for this particularly fantastic read!! I definitely really liked every part of it and i also have you saved to fav to look at new information in your site
Sat Jan 23, 2016Post  #5
RCC.
3928
2955
2169
can you suggest me the probable cost for onw wall of approx 10.5 X 12 Feet
Last answer on 11/13/2016 12:56:53 AM. Forum started by Lokesh Gupta
2875
2595
What are the size available What about strength of main door price details
Last answer on 11/18/2013 3:35:39 PM. by S L Gupta (Civil Engg). Forum started by padma
2399
1569
I would like to know where I can get the wall decor and how much it costs.
Last answer on 9/9/2011 10:50:08 PM. Forum started by Prakashrao
3542
Contruction Tool
3469
Cost of concrete walls
2803
i need an information regarding the minimum cost of a wall decor with painting..
Last answer on 8/4/2018 2:36:29 AM. by S L Gupta (Civil Engg). Forum started by anoo
5864
Estimation
2531
cost of plaster a block wall
Last answer on 2/27/2013 10:58:41 AM. by S L Gupta (Civil Engg). Forum started by kamlesh
2697
PVC WALL PANELS ,....PL I WANT THE COST TO COVER 200 SQ FT IN LIVING ROOM.
Last answer on 6/7/2015 1:35:53 AM. by JAI PRAKASH. Forum started by sanjay
3645
Compound Wall
3862
Compound Wall Construction
2835
13650
2275
wall
Last answer on 12/12/2012 12:27:36 PM. by S L Gupta (Civil Engg). Forum started by saif
11828
cost of rbc and rcc slab
5811
3792
9884
2670
4627
4143
2865
5006
3655
1864
2800
2610
2372
2462
2638
1807
3607
6254
A
Post
Post Painting Works
Home Decorating Tips
Your home is a place where you live, dont make it a workplace, dont mess up. Decorate your home in unique style. Use w..
Black
Black Bedroom Design Ideas
Decorate your bedroom with black. Black bedrooms are known for its bold and glamorous look. It is not necessary to pai..
Bedroom Decorating Ideas
Elegant bedroom décor may melt your all worries and tensions. Some simple but dazzling bedroom decoration or makeover ..
Plastering
Plastering
