Home -> Forums -> Construction -> Paints More -> WHAT IS THE COSTING OF VNYLE FLOORING PER SQ FEET.
Fri Jul 27, 2012Total posts : 1
mksharma
mksharma
Topic: WHAT IS THE COSTING OF VNYLE FLOORING PER SQ FEET.
Fri Jul 27, 2012Post  #1
Dear Sharma
          It is better to try rates in your city or town where work to be executed. As there is various types accrding to quality and thickness. Rate also varries for roll and tile flooring. The rates of vinyle flooring also link with crude oil and change day to day. Some quote is Rs 60-75 per sft and labor rate is 10-15 per sft.
Paints More-Construction Questions (26)
2732
present cost of constuction per sq feet
Last answer on 11/29/2011 3:40:09 PM. by S L Gupta (Civil Engg). Forum started by ajeett
3225
mosaic or tiles
Last answer on 3/19/2013 5:06:52 PM. by Jemimmarichardson. Forum started by aammiitt
2663
I want to know the cost of this flooring per square feet
Last answer on 8/27/2013 12:29:33 PM. by S L Gupta (Civil Engg). Forum started by b.jaganathan
2175
18382
2245
3995
Individual House Plan for 2200 Sq Feets
Last answer on 4/26/2021 12:30:53 AM. by Gunjan Utraja. Forum started by vishal
2270
i need to construct a 200 sq feet house on the 3 rd floor in pune what will be t
Last answer on 10/18/2016 5:14:48 PM. by Amit Hasija. Forum started by sandeepkelkar
7101
Cost of stilt floor construction
Last answer on 10/1/2009 3:08:55 PM. Forum started by Amar
1777
Last answer on 8/8/2016 2:46:05 PM. by S L Gupta (Civil Engg). Forum started by arvindkori
3925
2102
Types of Windows and Door options in uPVC
Last answer on 5/25/2015 12:51:15 PM. by JAI PRAKASH. Forum started by harsha gv
2972
duration of constucting home
1671
How many sq feet marble needed in 1700 sq feet area with kitchen and two floor stairs.
Last answer on 7/12/2016 10:45:15 AM. by S L Gupta (Civil Engg). Forum started by Dheeraj Grover
1601
Last answer on 10/18/2016 5:17:56 PM. by S L Gupta (Civil Engg). Forum started by Dheeraj Grover
5813
Industrial shed construction
Last answer on 1/8/2022 4:18:30 AM. by S L Gupta (Civil Engg). Forum started by shikha Chetal
5664
What is the cost of the emulsion paint per sq ft as per today's market rate?
Last answer on 2/14/2013 11:17:01 AM. by Jemimmarichardson. Forum started by Rani
8880
2411
Very useful Website for all the Professionals whoever involved in Construction F
Last answer on 12/31/2020 2:29:49 AM. by Gunjan Utraja. Forum started by suresh
2177
Painting old house
Last answer on 1/24/2017 12:52:24 PM. by S L Gupta (Civil Engg). Forum started by soumyabrata
1825
wall primer
Last answer on 1/10/2016 9:04:01 PM. by JAI PRAKASH. Forum started by Anu
1892
Wall Putty
Last answer on 3/11/2014 2:11:56 PM. by Abhishek Garg (Builder & Engineer). Forum started by Purvi Panchal
2187
Exterior wall putty
Last answer on 1/17/2014 11:53:01 AM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
1779
Place to buy cheap paints
Last answer on 10/29/2011 6:35:31 AM. Forum started by judyparker
What is acre
Designing
Designing a Foundation
Terrazzo
Refinishing Hardwood Floors
Checklists for flooring
Epoxy
Epoxy Flooring
Epoxy flooring can be defined as several layers of any type of epoxy resin that is applied on a floor surface. This ty..
