Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> CSEB vs Solid Concrete block for wall
Wed May 20, 2015Total posts : 6
aladin
aladin
Topic: CSEB vs Solid Concrete block for wall
I am thinking of building a cost efficient and energy efficient house.
I have two options in front of me
A) CSEB - Compressed Stabilised Earth BlocksCSEB - Compressed Stabilised Earth Blocks
B) Solid Concrete block
1)
I like interlocking  CSEB, but I don't its mud color lock and texture.
Is there a way to paint CSEB paint like a plastered-smooth wall without having it cement plastered  ?
I have heard grey cement coarse putty and paint works.
2)
Is Solid Concrete block house is more hot inside?
3)
Is 6" wall OK for two story residential construction using Solid Concrete block?
Attachments: concrete-solid-block-ordinary-plaster-finish-500x500.jpg on Wed May 20, 2015,&n
Thu May 21, 2015Post  #1
SOME LIMITATIONS OF CSEB
•    Proper soil identification is required or unavailability of soil.
•    Unawareness of the need to manage resources.
•    Ignorance of the basics for production & use.
•    Wide spans, high & long building are difficult to do.
•    Low technical performances compared to concrete.
•    Untrained teams producing bad quality products.
•    Over-stabilization through fear or ignorance, implying outrageous
•    Under-stabilization resulting in low quality products.
•    Bad quality or un-adapted production equipment.
•    Low social acceptance due to counter examples (By unskilled people, or bad soil & equipment).
Thu May 21, 2015Post  #2
aladin
aladin
Post subject: not a full answer to the question
Thanks for the reply.
I would appreciate if one answer all my three questions.
Fri May 22, 2015Post  #3
Sun May 24, 2015Post  #4
aladin
aladin
Can any expert answer my questions please?
Thu Jun 11, 2015Post  #5
aladin
aladin
Post subject: Can anyone anser?
I am awaiting a reply
Tue Jun 16, 2015Post  #6
1) Yes, Completed walls require either a reinforced bond beam or a ring beam on top or between floors (8')and if the blocks are not stabilized, a plaster finish, usually stucco wire/stucco cement and or lime plaster. Stabilized blocks create a brick wall that if properly stabilized can be left exposed with no outer plaster finish. There are also countless local materials that can be used for natural plasters and tuck pointing techniques that help to reduce the total cost of construction.
2) No, Also, due to the enormous mass — these are monolithic walls — CEB has excellent thermal performance, reducing heating and cooling costs.
3) No, Standards for foundations are similar to those for brick walls. A CEB wall is heavy. Footings must be at least 10 inches thick, with a minimum width that is 33 percent greater than the wall width. If a stem wall is used, it shall extend to an elevation not less than eight inches (203 mm) above the exterior finish grade. Rubble-filled foundation trench designs with a reinforced concrete grade beam above are allowed to support CEB construction.
2153
3433
19139
Solid cement block Vs Bricks
Last answer on 6/10/2012 11:29:35 AM. by jag2. Forum started by jag
3146
Last answer on 8/16/2013 1:12:41 PM. by S L Gupta (Civil Engg). Forum started by K S SHYAM SUNDER
2414
COSTING AND STRENGTH OF WALL
2628
Precasted Concrete Blocks
Last answer on 12/31/2020 2:22:20 AM. Forum started by Girish
1846
1732
5018
3470
Cost of concrete walls
1998
Concrete Hollow Block Masonry
2028
2191
Size of the Roof Level Beam in RCC framed structure
Last answer on 1/30/2015 12:12:31 PM. by S L Gupta (Civil Engg). Forum started by Arvind Bhaskar
1341
3082
2595
Last answer on 9/7/2012 4:18:47 PM. by S L Gupta (Civil Engg). Forum started by narsi vekeriya
5136
Use of Solid Concrete Bricks
1797
5811
3793
9885
2670
4628
4143
2866
5008
3657
1865
2801
2610
2374
2463
2638
1808
3608
6254
Concrete Decor
Water for Construction
Concrete Mix Ratio
