Foundation
Thu Sep 19, 2013
manishkumar
Topic: Calculation of column load and footings
Dear friend,
while calculating load on column (Dead + live load) here
Dead load= Self load of column+self load of beam+ load of brick wall +load of slab+ load of water tank +terrace finish load+water proofing load. with M20 and Fe415.
Live load = 4.0KN/m2 X area
(a) I am doubt whether the plinth beam self load need to be included to calculate the total load at column and footings.
(b)how we calculate the size of tie beam?
(c)how we can make footings in between two construction building ?
(d) which is better square or rectangular column and why?
(e)For a rocky surface how we assume Soil bearing capacity?
If possible plz reply Manish Kumar
footings and tie beam at plinth [Compatibility Mode].pdf on Thu Sep 19, 2013,
Manish-Ghar Expert.xls on Thu Sep 19, 2013,&n
Fri Sep 20, 2013
Dear Kumar
You know much more about design and loading calculation, The design is to study the latest design theory. As per query I am in opinion that
a) The weight of plinth beam should be taken in the design of column's footing. It is a small quantity and some time neglect it but it is covered under the factor of safety, which we keep 3.
b) Tie beam is a nominal structural member and goes through door opening and window opening and design like wise of door and window opening/ span.
c) Query is not clear which two building, distance between them etc.
d) It depends upon design calculation and architectural feature.
Sat Sep 21, 2013
manishkumar
Post subject: Thanks
Thanks for answers. These all become possible due to yours articles and internet.I salute your dedication towards queries and response.
Manish Kumar
Foundation-Construction Questions (38)
2838
how to make footing and column for g 2 building on water well
Last answer on 4/1/2013 7:09:40 AM. by
Arun
Arun
2102
Last answer on 2/14/2021 11:35:17 PM. by
Ravi sharma
2619
COLUMN nd LOAD BEARING
Shivaraj
Shivaraj
1940
Last answer on 11/25/2016 2:18:45 PM. by
Khalid Rashid
Column sizes for Individual House with G+2 design
Last answer on 7/12/2016 1:46:04 PM. Forum started by
Venkat
1969
Dear Sir,Can you please tell me the size of the column and footing for individua
Last answer on 11/25/2020 5:27:11 AM. by
Venkat
Venkat
6418
Last answer on 8/17/2012 11:30:19 AM. by
gangula
3346
Column footing size
Last answer on 7/4/2020 2:00:01 AM. by
Pooja
3513
Last answer on 5/19/2015 9:12:55 PM. by
Wiki
3942
Last answer on 2/15/2013 11:15:40 AM. by
prassant kumar
prassant kumar
3007
i wana construct a 18X14 feet hall single story .Is 9x9 column at corner os suff
Last answer on 9/19/2013 2:12:08 PM. by
manishkumar
manishkumar
1765
Last answer on 2/3/2022 7:29:44 AM. by
Akhil George
2570
Last answer on 7/16/2012 11:45:56 AM. by
George Kattapuram
4801
Last answer on 1/13/2014 2:23:28 PM. by
balaji
4333
Last answer on 3/15/2011 6:15:21 PM. by
Mohini Sharma
kanwer sajjad
2157
New 4 storey building design
Last answer on 3/5/2016 10:15:22 PM. by
Raidang
1903
Column projection/Technical query
Last answer on 3/18/2021 3:16:35 AM. by
Pooja
1702
How should be footing net for column adjacent to existing wall
Last answer on 6/3/2017 3:04:50 PM. by
Surinder Singh
1534
Last answer on 12/2/2016 11:43:21 AM. by
ranjeet
2688
Pillar
Last answer on 2/24/2022 11:04:22 AM. by
keshavthakur
2142
Curing urgent
Last answer on 2/23/2022 5:17:08 PM. by
Rohit Sharma
Pooja
2375
structure work
mamtagarg
manish agarwal
5167
Pillar foundation
Last answer on 2/1/2022 10:02:34 AM. by
joe kurian
joe kurian
2209
new house
Last answer on 1/5/2022 2:13:15 AM. by
Janette
ananth
2822
building a house
nashir
1993
Construction Agreement
Last answer on 12/21/2021 12:56:56 AM. by
Abhijit
3091
Foundation
kamal
2275
Foundation
Last answer on 12/20/2021 6:20:53 AM. by
Gagandeep
1478
Last answer on 11/13/2021 8:11:49 AM. Forum started by
passwordc
3665
Foundation
Rohit Sharma
2117
Structure proof checking
Arnab Ghosh
2559
Foundation design
DavidFlores18
nithun
2464
Last answer on 5/22/2021 11:37:00 PM. by
mayowa
2470
Saria and cement
Last answer on 3/25/2021 4:28:11 AM. by
ARVIND GOYAL
3658
Wall Thickness
Last answer on 12/31/2020 2:31:58 AM. by
shankar
2679
Last answer on 7/28/2020 12:37:29 AM. by
K M Sendhil
3181
satya
13271
Steel Type
Last answer on 7/4/2020 2:48:38 AM. by
erbharathi
sumit dua
Designing a Foundation
Specification of Steel
