Home -> Forums -> Construction -> Layout and House Plans -> Can I build a loft inside a flat with 'bout 20ft ceiling height? Do I need permissions from the Govt.?
Fri Jul 25, 2014Total posts : 1
Vansh
Vansh
Topic: Can I build a loft inside a flat with 'bout 20ft ceiling height? Do I need permissions from the Govt.?
I have found a particular 3BHK flat with an upfront garden and am getting it at a great deal since it's the builders own flat.
What I was wondering was that, since the celling height is double than the normal would be use it to my advantage to construct a loft and create an overhead space to shift dinning table and relaxation balcony space or anything to make it a part duplex.
Will I be able to build one strong enough to support it over head? Maybe by using beams and hiding it with wood work?
Plus, would there be any specific permissions required? or since it's interior work, I'm free to do anything on my will?
Any input is greatly appreciated, since I have to make a decision wether or not to buy that place.
Attachments: J307743119.3bhk-wing-type-b-floor-plan.58510l.jpg on Fri Jul 25, 2014,&n
Fri Jul 25, 2014Post  #1
No permission required for any interior wall addition but it may require if you are removing one.
Layout and House Plans-Construction Questions (40)
2567
building permission
Last answer on 3/18/2014 1:12:06 PM. by S L Gupta (Civil Engg). Forum started by qader
1947
What is the floor height needed for my living home?
Last answer on 7/6/2013 12:06:05 PM. by S L Gupta (Civil Engg). Forum started by ananth
3002
roof height
Last answer on 4/15/2021 2:13:51 PM. by majomathew. Forum started by majomathew
1939
For doing false ceiling which direction we should bring down/up in desing
Last answer on 2/22/2021 2:30:00 AM. by S L Gupta (Civil Engg). Forum started by PALLAVI
2963
i want desings of fall ceiling in apartment flat
Last answer on 3/12/2021 10:49:40 PM. by G N Shaikh. Forum started by shrenik
2137
please send me a vaastu plan for a south facing site-size 100ft width brath-20ft
Last answer on 7/26/2009 1:29:45 AM. by Priti Arora. Forum started by ruchika
2444
reference about the distance needed for house from near by temple and height res
Last answer on 6/18/2021 11:18:23 PM. Forum started by George Cherian K
2214
what's this flooring?
Last answer on 1/23/2013 6:10:59 PM. by Jemimmarichardson. Forum started by aammiitt
3083
I need one good arch drawing for inside of home
Last answer on 5/18/2021 7:38:31 PM. by Sudheer Kumar. Forum started by Sudheer Kumar
3520
i need to know about the lift position and can the lift come inside the house
Last answer on 12/31/2020 2:31:44 AM. by Karan. Forum started by vkausalya
2980
Last answer on 12/31/2020 2:26:35 AM. by rajendrakumar. Forum started by mary cecil
1283
HAI, MY BUILDING GROUND FLOOR HEIGHT 11.25FTS
Last answer on 7/4/2020 4:24:16 AM. by S L Gupta (Civil Engg). Forum started by VASUDEVA KUMAR
2648
Last answer on 12/31/2020 2:26:56 AM. by Raji. Forum started by Kannan
3126
Dining Room Ceiling
Last answer on 7/2/2020 8:51:19 PM. by O'SirTee. Forum started by atiq khan
4099
false ceiling design needed for bedroom
Last answer on 2/17/2022 3:35:09 AM. by JosephCarlo. Forum started by chandru
1888
What will be cost increse for every foot increase in height of ceiling ?
Last answer on 2/22/2013 11:42:44 AM. by S L Gupta (Civil Engg). Forum started by s.m.sudhan
1342
how can i get permission from nagar nigam
Last answer on 2/15/2015 10:36:08 PM. by JAI PRAKASH. Forum started by deepak agrawal
1871
I'm Working at a govt. approved Project
Last answer on 1/7/2011 6:57:12 PM. by S L Gupta (Civil Engg). Forum started by sanjeev pradhan
1616
MY NAME IS CHAITHRA.S MY DOB 10/7/1995 I TRYING FOR GOVT JOB
Last answer on 12/29/2014 11:27:32 AM. by seema tyagi. Forum started by CHAITHRA S
2332
HOME INTERIOR
Last answer on 12/19/2012 11:37:08 AM. by S L Gupta (Civil Engg). Forum started by NAVDEEP
2697
2930
2194
2194
2809
4531
1898
2292
2278
2779
3474
2364
1980
2254
3602
2099
2801
1558
2128
Dining
Dining Room Ceiling
Kids
Kids room ceiling designs
How to clean plaster ceiling?
Ceiling
