Can anyone suggest the breakup ratio percentage cost like up to plinth beam, up
Tue May 29, 2018Total posts : 1
Shaik ibrahim
Shaik ibrahim
Topic: Can anyone suggest the breakup ratio percentage cost like up to plinth beam, up
Can anyone suggest the breakup ratio percentage cost like up to plinth beam, up to slab, superstructure, final finishing..Assuming cost of construction 1400 per sft. For i dependent residential building. Thank you
Tue May 29, 2018Post  #1
          The cost break up is possible with the help of cost detail estimate.
   For example you have foundation depth 3' in other case foundation depth is 4' or 5' than how can you fix the cost ratio.
  See the link of detail estimate
Regarding Beam
9195
2281
which marble and its sub category to buy
Last answer on 7/3/2020 11:36:27 PM. by JAI PRAKASH. Forum started by sushantsah
3129
Plinth beam at ground level
6529
2232
Is plinth area and builtup area are same?
Last answer on 9/21/2016 12:10:11 AM. by Pawan kumawat. Forum started by hariprasad
83
Love Breakup Solution By Astrologer 91-9056562757
Last answer on 4/26/2024 12:21:05 AM. Forum started by Pandit Sahil Sharma Ji
79
Last answer on 4/26/2024 12:21:06 AM. Forum started by Pandit Sahil Sharma Ji
87
Last answer on 4/26/2024 12:21:07 AM. Forum started by Pandit Sahil Sharma Ji
80
Last answer on 4/26/2024 12:21:09 AM. Forum started by Pandit Sahil Sharma Ji
88
Last answer on 4/26/2024 12:21:10 AM. Forum started by Pandit Sahil Sharma Ji
82
Last answer on 4/26/2024 12:21:11 AM. Forum started by Pandit Sahil Sharma Ji
91
Last answer on 4/26/2024 12:21:12 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 4/26/2024 12:21:13 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 4/26/2024 12:21:14 AM. Forum started by Pandit Sahil Sharma Ji
87
Last answer on 4/26/2024 12:21:15 AM. Forum started by Pandit Sahil Sharma Ji
87
Last answer on 4/26/2024 12:21:16 AM. Forum started by Pandit Sahil Sharma Ji
84
Last answer on 4/26/2024 12:21:17 AM. Forum started by Pandit Sahil Sharma Ji
85
Last answer on 4/26/2024 12:21:21 AM. Forum started by Pandit Sahil Sharma Ji
Centering
Concrete Mix Ratio
Dining
Dining Room Ceiling
Designing
Designing a Foundation
Cement
Cement Concrete
Through
