How to do leveling of concrete in wooden block flooring Going for wooden block flooring and want to know how to do leveling of concrete in wooden block flooring, go through v.. |
What is the recommended method for leveling of concrete in wooden block flooring? The leveling layer of concrete shall be cement concrete 1:2:4 (1 cement,2 coarse sand,4 stone aggregate 10 mm nominal .. |
How to level concrete sub floor before installing wooden block flooring? The recommended method for leveling of concrete in wooden block flooring is described in the writeup. |
| Tips to keep your home germ free Making your home germ free and clean is not a major project. Just follow some tips described here and you are done for.. |
| How to get rid of ants Ants are most common insects encountered around house, gardens and buildings. Ants become problems when they are found.. |
Cement Concrete Raw Material Read points should be kept in mind while collecting raw materials for cement concrete in construction work.
| Lights, Design & Action Light not only illuminates but define one’s path. It can change mood, hide or highlight an object, kill or liven up a .. |
| Through rate-contractor; guidelines for better relationship! Everyone wants to build a dream home but no-one wants the hassle that comes in day-to-day construction work. Here are .. |
| Importance of Proper Water Supply and Sewerage during construction Construct Sewerage and Water Supply of your house properly else you have to face many hygienic problems.Generally it i.. |
