Home -> Forums -> Construction -> Start Construction -> Can some one guide me on laying concret slab
Thu Aug 26, 2010Total posts : 1
nuwan77
nuwan77
Topic: Can some one guide me on laying concret slab
Hi Kind People,
I am constructing a house for my family. I now at building the first floor slab. As a result, I am curious to know what are the guide lines that I should take when talking to slab-contractors, and checking their work for quality.
For example, recently I got to know that one cement bag (50KG) needs about 25 liters of water under 2:5:7 (cement : sand : aggregate3/4").
Another example is about the bending of steel. I heard a steel rod must be bent on 3 positions near the joint to transfer the weight/tension equally to the adjoining rod.
I want to know things like these, or rules of thumbs and few tips to cross check the work carried out by the construction team.
Any ideas to add some light to this topic?
Thanks in advance.
Nuwan
Fri Aug 27, 2010Post  #1
Dear Nuwan
               You are laying RCC slab for your dream house and want some instructions to be followed by you. As about MS steel bars tri to take full length, if not possible than provide proper overlap i.e. equal to 45 x dia of the bar, bars should be free from rust and have proper cover. As for concrete material cement should be fresh, sand should be coarse sand free from silt and bazri should be free from silt etc. As per water there should be 32 liter of water required for conc. Mix of 1:2:4 and 30 liter required for Mix 1:1.5:3. For more detail you should see the concrete section of construction in gharexpert.com website, some links are given below.
http://www.gharexpert.com/category/1470/Cement-Concrete-0.aspx?PL=2&Estimator=
http://www.gharexpert.com/articles/Cement-Concrete-1730/Mild-Steel-Bars-in-Cement-Concrete_0.aspx
http://www.gharexpert.com/articles/Cement-Concrete-1095/What-precautions-should-taken-while-mixing-laying-cement-concrete-mix-to-required-site--0.aspx
http://www.gharexpert.com/articles/Cement-Concrete-1096/What-quantity-water-required-cement-concrete--0.aspx
2407
Related to Sunken Slab
4010
labor rate for RCC work
4836
2125
CRACK IN CENTRE OF SLAB
3087
2000
can someone share me duplex house plan for 14x40 plot already first slab isdone
Last answer on 7/24/2015 8:42:01 PM. by JAI PRAKASH. Forum started by Anju Vaishnav
2525
3133
false ceiling
1617
suggest layout 36fit by 60 fit
Last answer on 5/29/2015 10:34:14 AM. by seema tyagi. Forum started by Ashish
2220
Last answer on 5/24/2021 4:53:02 AM. by Abhishek Garg (Builder & Engineer). Forum started by vamsi
2895
Terrace water proofing
cost for completion
Last answer on 10/19/2014 3:40:13 PM. Forum started by jithin
2829
9552
Last answer on 10/17/2016 1:19:41 PM. by Vishal Thakur. Forum started by Vishal Thakur
1885
Last answer on 4/12/2015 5:58:38 PM. by D.C.tandon. Forum started by SREENIVAS K
1783
Laying RCC slab
Last answer on 2/3/2015 11:57:39 PM. by SAROJINI. Forum started by SAROJINI
2575
Cost of Pillars and slab
Last answer on 6/13/2013 11:43:13 AM. by MANJUNATH. Forum started by MANJUNATH
2126
3310
Buying
Buying Guide for Garage Door
Guideline for laying DPC
Vastu for Kitchen
