Sat Jun 22, 2013Total posts : 1
kk
kk
Topic: Can some please comment the common mistakes we do in home electrical wiring and plumbing
Can some please comment the common mistakes we do in home electrical wiring and plumbing and the counter measures...like do's and dont's...
Mon Jun 24, 2013Post  #1
Electrical mistakes are common in each and every house that may be dangerous for residents. When you are designing your dream home it may be that you are not aware about the electrical mistakes and its effects. When you start living in the home and experience the electric faults that will be panic for you. You can experience these problems because of faulty electrical work, unskilled electrician or low quality electrical material. Sometime, electricians do not work properly while running wires, drilling holes and nailing up boxes to save time or sometimes it happens accidentally. These are some common mistakes that happen often. These mistakes may be safety hazard and can cause electrical fires. Here are discussed some common electrical problems that can be harmful for residents.For detail study see the link below.
http://www.gharexpert.com/articles/Wiring-Electric-fitting-2088/Common-Mistakes-in-Electrical-Work_0.aspx
http://www.gharexpert.com/articles/Drainage-,-Sanitary-System-Plumbing-1813/Purchasing-Guidelines-Sanitary-material-Pr_0.aspx
2965
2513
2599
JOINERY WORKS
2024
3400
Bathroom Cleaning Tips
2281
Plumbing works
2340
electrical installation
Last answer on 11/27/2021 2:32:14 AM. by Navneet Jharia. Forum started by brajesh pandey
2727
electrical
Last answer on 7/3/2020 9:50:06 PM. by JAI PRAKASH. Forum started by sunil kumar
Ac and Electrcial
2015
space parameter for sanitary fittings
Last answer on 1/23/2016 8:28:13 PM. by JAI PRAKASH. Forum started by sandeep yadav
3628
Wall unit
1923
electrical work in house
Last answer on 9/4/2021 6:00:39 AM. by JAI PRAKASH. Forum started by milind
1723
Request for electrical and Plumbing Materilas list
Last answer on 10/10/2014 12:52:53 AM. by JAI PRAKASH. Forum started by endayveed
1968
electrical and plumbing work
Last answer on 12/11/2013 11:20:51 AM. by S L Gupta (Civil Engg). Forum started by neelam rathi
3690
cost of plumbing,sanitaion,electrical as %of civil work
Last answer on 11/16/2021 12:22:16 PM. by muralibgowda. Forum started by naina
2882
Last answer on 9/30/2020 7:45:37 AM. by Vijay Mishra. Forum started by SCK
2306
Electrical Wiring
Last answer on 5/16/2013 12:22:40 PM. by S L Gupta (Civil Engg). Forum started by Unnikrishnan
2187
SoLuTioN:fOR tO 91- 8769373431KaLa jaDu VaSHiKArAn SPeCiAlIsT
Last answer on 12/27/2024 11:23:30 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:23:24 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:23:18 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:23:11 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:50 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:44 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:38 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:33 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:26 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:20 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:14 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:05 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:21:47 PM. Forum started by rupeshji
31
Last answer on 12/27/2024 11:21:38 PM. Forum started by rupeshji
41
Last answer on 12/27/2024 11:21:31 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:21:25 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:21:19 PM. Forum started by rupeshji
17
Last answer on 12/27/2024 11:21:12 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:21:03 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:20:57 PM. Forum started by rupeshji
Kitchen design mistakes
Electrical
Electric
Electric Shock Proof Home
Earthing
What is binding wire
