Fri Feb 01, 2013 | Total posts : 1 |
| Topic: Can store room be constructed above puja room in east direction of the house.
Can store room be constructed above puja room in east direction of the house. |
Articles that might interest you! | | Gharexpert can save you money during construction Do you know almost all individual home construction projects in India take more money to complete than what people ori.. | | The 4 Cardinal Directions The directions are one of the most important factors in both Feng shui and Vaastu. The positioning of main entry door, v | | EAST FACING PLOT A north-east facing plot is best for all type of constructions, whether a house or a business establishment. However, .. | | Are you constructing a cupboard, Learn the difference between wood-only and wood-brick cupboards Cupboards construction using different materials: Brick and Wooden Cupboards, Just Wooden Cupboards, Mesh Cement and W.. | | Which types of bricks are recommended to protect the dampness while constructing the building? The density of masonry bricks used must be greater than 1200 kg/m³. | | Planning a House Once the architect has given his design options, it becomes necessary to select one and start working on it. | | Layout of Building The real meaning and purpose of setting out (layout) is to transfer the plan, length and width of its foundation on th.. | | Swimming Pools to Match Your Lifestyle Swimming pools are rich sources of pleasure. They not only amuse us but energize the body also. They provide extreme r.. | | Inground Swimming Pool If you are planning to install an in ground swimming pool in your home, you can find a range of designs and styles to .. | | Painting Exterior of your Home For painting exteriors of your home, you should know proper guidelines on primer, paint quality, paint color, weather .. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
