Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Can we construct 4inch wall on extended slab after horizontal beam ?
Fri Nov 11, 2016Total posts : 0
sravan
sravan
Topic: Can we construct 4inch wall on extended slab after horizontal beam ?
Hello,
We are constructing a two floor house, and are planning to construct a 4 inch wall on extended slab which is 40 feet long and 3.4 feet wide from beam.
Please advise, if it is safe to construct wall on cantilever slab.
I attached a picture of my house plan.
Thanks,
Sravan.
Attachments: 2016-11-11_1239.png on Fri Nov 11, 2016,&n
21875
1657
2525
1951
2659
construction of wall on two feet extended slab from the beam
Last answer on 9/1/2014 10:53:32 AM. by S L Gupta (Civil Engg). Forum started by aditya
735
Hi all. I am constructing my new house. My contractor has built 9 inch red brick
Last answer on 7/25/2020 5:43:09 AM. Forum started by Rishi Panda
8110
Wall on roof slab with no beam underneath
Last answer on 9/29/2020 11:34:24 PM. by S L Gupta (Civil Engg). Forum started by Joydeep
1366
2557
5861
4056
2177
Room wall not on Beam
Last answer on 7/3/2020 11:24:10 PM. by Purvi Panchal. Forum started by vijay
3129
Plinth beam at ground level
4012
labor rate for RCC work
3721
13772
overlap length to steel
11829
cost of rbc and rcc slab
1846
1287
I want to build bedroom loft of 2 feet extend from wall. The side walls are 11'
Last answer on 7/4/2020 4:18:19 AM. by Surinder Singh. Forum started by Surinder Singh
5811
3793
9885
2670
4628
4143
2865
5008
3657
1865
2801
2610
2373
2462
2638
1807
3608
6254
Centering
Reasons of dampness
Canvas
Canvas Wall Art
