Home -> Forums -> Construction -> Brick work -> Can we construct 9" Wall on Extended Slab (Cantilever) after Horizontal Beam ?
Wed May 11, 2011Total posts : 10
Sambasiva Rao Ravuri
Topic: Can we construct 9" Wall on Extended Slab (Cantilever) after Horizontal Beam ?
Am constructing a Duplex in Chennai.
I have the follwing doubt.
Can we construct 9" wall on the Cantilever slab ( slab extended after Horizontal Beam) .
Kindly clarify.
S. Ravuri.
Thu May 12, 2011Post  #1
Dear Rao
 You have not given full information i.e. what is the length and width of  cantilever, why you want to construct 9'' thick wall and what is the height of the wall and wll having any window etc.
In general the cantilever is 3' or 4' from wall or beam and 4.5'' thick wall is to be constructed on the cantilever portion. Keep the height minimum as possible and provide window/ ventilator to reduce the load.
 If you are not satisfied than send detail quarry, Iwill try to answer your quarry.
Thu May 12, 2011Post  #2
Post subject: Can we construct 9" Wall on Extended Slab (Canti...
Thanks for quick response.
Length of the Cantilever is 17 feet and 2 feet width. As this wall is an external wall, planning to go for 9"  and the height of the wall is 10 feet and planning to keep 5 *6 French Window.
Please note that in  the actual plan it is showing two 2 * 4 windows ( Qty- 2). But am planning to go for 5*6 Window.
Please find attached plan for the same.
S.Ravuri.
Attachments: Floor Plan.jpg Thu May 12, 2011,&n
Thu May 12, 2011Post  #3
Dear Rao
 After seeing the details sent by you I am in the view that you should go ahead for constructing the 9'' wall. But care should be taken that when you lay roof or slab of this area than load should be given on the stair side wall and on the wall which is parrallel to stair wall.
Thu May 12, 2011Post  #4
Thanks for prompt response.
Since we are doing RCC based construction, only columns & beams are constructed before laying the roof slab. Walls will be constructed later. My understanding is, the load of the slab goes to beams first and then to columns and finally to foundation. Let me know in this scenario, if we need to worry about the following point,
 load should be given on the stair side wall and on the wall which is parrallel to stair wall.”
Fri May 13, 2011Post  #5
Dear Rao
              About load my point is that do not make the wall of cantilever as load bearing. Load should be given in the other direction on the wall or beam as the case may be.
Tue Jan 31, 2012Post  #6
Basha
Basha
Post subject: 9" wall on cantilever slab
Sir, Can we 9" wall on cantilever slab spanning about 18' and projecting 2.5' from the wall. And the entire structure is a load bearing structure.
Details are as shown in attachements.. please suggest me at the earliest sir.
Attachments: Basha Plan.pdf Tue Jan 31, 2012,&n
Tue Jan 31, 2012Post  #7
Basha
Basha
Continuing my earlier msg here is what i had done to support my FF 9" wall over the same cantilever slab projecting 2.5" from a 15" SSM load bearing wall.
1. Provided 3 cantilever 9" x 9" beams over the slab to support the tip Simply supported beam to take up the load of 9" wall of FF.
2. have provided 2 windows of 3' x 4' so as to avoid direct loads.
As my structure is a load bearing one. Am i correct what i have done in transfering the loads using beam systems.
Please let me know what i have done is it correct and can i move on with my constructions or avoid 9" wall over that cantilever slab.
For further references am attaching the New Reference plan please have a look at this new plan.
Please reply at  the earliest sir..
Attachments: Basha New Ref Plan.pdf Tue Jan 31, 2012,&n
Thu Mar 28, 2019Post  #8
Deepak
Deepak
Post subject: Wall on Extended Slab (Without Cantilever and hi...
I want to make a 9'' brick wall over the Slab  which have no cantilever, My contractor didn't give any cantilever or hidden beam below the slab. It is simply extended slab of 2 feet from the column or main wall. They said that we can give parapet balcony wall but i want to raise 9'' wall on it. Kindly suggest what should i do now. Can we make some arrangement that i can put beam over the slab again & raise the wall on it ?? Please suggest me. I have attached the structure of slab, column & beam.
Attachments: Slab Structure4.jpg Thu Mar 28, 2019,&n
Fri Mar 29, 2019Post  #9
          1.  Construct 4.5'' thick wall and keep window/ ventilator in the wall to reduce the weight.
  2. Take help from any local engineer of your city who can solve the problem after visiting the house site.
Sun Feb 23, 2020Post  #10
Post subject: Need advice
There is a Cantilever extension of beam and both side of the cantilever is having column. length of the cantilever is 10ft. width is 1 ft one side and 1.5 ft other side. thickness of the cantilever is 6 inch
Is it safe to make 8 inch wall of 10 ft hight with a window of 6x7 ft
1366
Dear sir , A small doubt can we construct a 9" wall( 4
Last answer on 5/30/2019 3:21:33 AM. by Kranthi. Forum started by Kranthi
2450
Can we construct 4inch wall on extended slab after horizontal beam ?
Last answer on 11/13/2016 12:54:20 AM. Forum started by sravan
1657
2659
construction of wall on two feet extended slab from the beam
Last answer on 9/1/2014 10:53:32 AM. by S L Gupta (Civil Engg). Forum started by aditya
2525
1950
1982
Outer main wall to compound wall outer 10'9" distance. We constructed first flig
Last answer on 7/4/2020 4:23:29 AM. by S L Gupta (Civil Engg). Forum started by Prabu
735
Hi all. I am constructing my new house. My contractor has built 9 inch red brick
Last answer on 7/25/2020 5:43:09 AM. Forum started by Rishi Panda
8110
Wall on roof slab with no beam underneath
Last answer on 9/29/2020 11:34:24 PM. by S L Gupta (Civil Engg). Forum started by Joydeep
1661
Hi Sir,You are providing a great service to the society.We are extending our exi
Last answer on 11/21/2020 5:47:39 AM. by hooika. Forum started by Sai
1287
I want to build bedroom loft of 2 feet extend from wall. The side walls are 11'
Last answer on 7/4/2020 4:18:19 AM. by Surinder Singh. Forum started by Surinder Singh
1366
1668
Porch and bedroom on top having 1.5 m cantilever
Last answer on 11/7/2016 7:34:28 PM. by Sajeev. Forum started by Sajeev
2483
Extending the existing cantilever
Last answer on 3/30/2017 12:58:03 PM. by S L Gupta (Civil Engg). Forum started by Abhi
2557
5861
4056
2289
slab
Last answer on 12/20/2021 5:13:48 AM. by ringwang. Forum started by ringwang
3669
wals
3262
compound wall
3280
Bedroom Wardrobes information
2245
2206
1494
1965
1732
2224
2523
1501
1909
Brick or ACC block
2025
1653
1702
4687
Brick wall on RCC slab
3928
2617
Centering
Reasons of dampness
Canvas
Canvas Wall Art
