Can we construct toilet without sunken area ? If yes, how to do it.
Thu Jul 12, 2012Total posts : 8
Kapil Singhal
Kapil Singhal
Topic: Can we construct toilet without sunken area ? If yes, how to do it.
Fri Jul 13, 2012Post  #1
Dear kapil
       When we are constructing toilet on slab i.e. in upper story
1. If we want to fix english seat in the toilet than there is no need of sunken floor.
2. If we want to fix Indian seat in the toilet than foor either to be sunk or raised.
Sat Jul 14, 2012Post  #2
P. Panchal
P. Panchal
Yes you can make it . But floor of toilet will be raised a few inches
In case of Western commode Seat  floor will raise 6 inch, but in case of Indian seat it will raise about 12 to 15 inch.
Mon Jul 16, 2012Post  #3
Kapil Singhal
Kapil Singhal
Thanks for the replies.
Slab has already been laid. At that time Architect did not caution about this that in this case floor of the toilet will be raised.
I have consulted few sanitary persons also and they also say the same, that floor will be raised.
I want to avoid raising of the floor level.
English seat will be used.
Is there any other option than to raise the floor level ?
If in worst case I have to raise the floor level, then what is the maximum inches it would be raised ?
6 inches raise is like going one step of a staircase.
Mon Jul 16, 2012Post  #4
Dear Kapil
            It will depend upon the position of your toilet, If the toilet is at the end wall than in case of english seat the raising may be avoided because the out let pipe go through the wall with toilet. The second method to avoid raising is that to lift whole of the floor of 1st story i.e. lay 2'' cinder and  base coat 2'' cement concrete with brick ballast, than in this 4'' margen will be sufficent to take the out let pipe from the toilet.
Sat Aug 17, 2013Post  #5
Vaikuntam
Vaikuntam
Dear Kabil
you can make 4" hole where you will have EWC and Floor gully and bring down the pipe to ground floor slab bottom where you can fix your P Trap and floor gully then harizondaly bring the pipe out of building
this is the procedure we use in gulf countries if ground floor owner is diffrent then this is not possible
Vaikuntam
Sat Aug 17, 2013Post  #6
GUNA
GUNA
Hi Kapil
you can follow as Mr. Vaikuntam method and put false ceiling to cover the pipe lines
this how in multistory apartments in Chennai also execute. this solves most of the seepage problem in future and rectification cost also low if any seepage in future
Sun Aug 18, 2013Post  #7
sachin
sachin
Dear Vaikuntam/Mr Guna ,
In case the  trap is below the floor slab wont the water level will come down as there is a additional pipe between the closet and trap and cleaning the closet upto the water level will be tedious and some surface unreachable to clean ,leading to odour creation ?
Sun Aug 18, 2013Post  #8
GUNA
GUNA
Hi Kapil
FOR WALL MOUNT EWC YOU CAN TAKE PIPE LINE DIRECTLY THROUGH THE WALL(EXTERNAL WALL), YOU HAVE TO PUNCH THE SLAB(CORE CUTTING METHOD) ONLY FOR FLOOR SUMP(WASTE WATER LINE)
sunken slab
Last answer on 7/3/2020 11:00:06 PM. by S L Gupta (Civil Engg). Forum started by chethan
2149
Sunken slab
Last answer on 1/17/2021 5:51:16 AM. by freekundli. Forum started by Bhaskara
2895
Sunken toilet
Last answer on 6/16/2015 4:07:50 AM. by JAI PRAKASH. Forum started by manjula
Related to Sunken Slab
2931
3599
What can be done to remedy toilet and bath in north east
Last answer on 8/12/2010 4:21:43 PM. by sabina vanjani. Forum started by Sathya
3629
sunken slab
2245
hi sir,here is the toilet layout for a house im doing...is there a need for a su
Last answer on 4/12/2015 6:07:10 PM. by JAI PRAKASH. Forum started by amog
480
Is it possible to create your own company without knowledge in this area?
Last answer on 1/25/2022 11:59:36 AM. by Rinder76. Forum started by Salammm
1569
toilet in south west area of house, is it bad,what are remedies to correct it
Last answer on 12/23/2016 11:16:11 AM. by S L Gupta (Civil Engg). Forum started by sonia agarwal
2115
suppose i take all water pipes through sunken area along the length and breadth
Last answer on 7/23/2011 2:18:10 AM. Forum started by D.Ramachandran
3645
vaastu for east facing plot where should the toilet constructed
Last answer on 3/5/2021 3:03:04 PM. by nilu. Forum started by vankamardi
3663
CAN WE CONSTRUCT COMBINED BATHROOM AND TOILET IN NORTHWEST
Last answer on 5/31/2014 11:05:07 PM. by JAI PRAKASH. Forum started by VIKAS
9555
Last answer on 10/17/2016 1:19:41 PM. by Vishal Thakur. Forum started by Vishal Thakur
2163
I am planning to construct an house in Guntur and it is a 2 road bit and dimensi
Last answer on 3/17/2015 11:46:59 AM. by seema tyagi. Forum started by Narendra Kumar Saranam
1662
Project cost for a hostel
Last answer on 8/20/2015 2:22:16 AM. by JAI PRAKASH. Forum started by Shiv Pyari Singh
2196
1570
1579
is it a right decession to buy a plot and construct a house opposite to temple w
Last answer on 10/4/2015 12:47:27 AM. by JAI PRAKASH. Forum started by K.Bizilikumar
15
17
Utilization
Rugs
Rugs for Living Room
Bathroom Cleaning Tips
