Home -> Forums -> Interior -> Kitchen -> Can we create modular kitchen in concrete
Tue Mar 15, 2016Total posts : 7
Topic: Can we create modular kitchen in concrete
Hi
Rather than getting a modular kitchen done in wood. Can we get that done using concrete? if yes, please explain how?
Ravi
Tue Mar 15, 2016Post  #1
Dear Ravi
           In my opinion it is not possible to make modular kitchen using concrete but you can make the shelves with RCC and cabinet shutter of wood.
Tue May 03, 2016Post  #2
It is not possible in RCC. It can be made of stone where you can use wooden shutters.
Mon Apr 30, 2018Post  #3
Thank you sir
Sun Jun 24, 2018Post  #4
Thank you sir
Sat Aug 04, 2018Post  #5
Thank you sir
Fri Aug 10, 2018Post  #6
Amit
Amit
Partially you can do. Carpenters make full board/playwood boxes and then fix counter with Areldite on top. After counter and boxes are fixed tiling is done on backsplash area.
However
I have done partial concrete modular kitchen in my current flat some 15 years back. Its a U shape kitchen with 40mm granite. If I would have gone for full plywood boxes as interior designer suggested then cost would have been huge because granite was quite thick and heavy. So I placed granite slabs on brick amd mortar support. After that shelves were made just like how it is done in wardrobes and Blum channels and steel baskets were fitted.  On one side it is full sliding steel baskets and on opposite under platform is storage area with shelves
In the area were I wanted just storage and no sliding Only wooden frame and shutters were fixed and shelves were made with 13mm ply.
These days a better material called wood-cement board / fiber cement board is available in market. It is also available as pre-laminated from both sides.
You can use this for boxes and shelves as it is 100% water proof anf stronger then ply.
For shutters use ply with lamination as fiber cement board is heavy so not good for shutters.
I am planning to do construction of independent house and this time will go for wood- cement for wardrobes and kitchen except shutters.
Popular brands of wood-cement are shera board , century zyrcon , V board .. there are two finishes one for exterior cladding and another 6x4 board for interior partition work.
Mon Aug 20, 2018Post  #7
Thank you sir
Kitchen-Interior Questions (39)
8125
Modern Kitchen
Last answer on 2/19/2022 3:13:17 AM. by Gohkadd. Forum started by ankita
3925
Kitchen Cabinets
Last answer on 7/3/2020 9:37:52 PM. by leelindsey. Forum started by madhuri
3644
Last answer on 10/11/2020 7:16:16 AM. by Amit Hasija. Forum started by disha gupta
3211
modular kitchen photo or bed design
Last answer on 7/4/2020 4:23:39 AM. by S L Gupta (Civil Engg). Forum started by sanjay
4266
any gud designer for modular kitchens in bangalore
Last answer on 7/4/2020 2:23:27 AM. by Dinesh Mittal. Forum started by pv rao
2858
modular kitchen
Last answer on 2/23/2022 4:38:18 PM. by JAI PRAKASH. Forum started by Anu
3285
Kitchen modular size 8*8 fit
Last answer on 10/11/2020 7:13:57 AM. by JAI PRAKASH. Forum started by Hitendra singh bhadoria
2112
Last answer on 1/27/2015 7:29:54 PM. by JAI PRAKASH. Forum started by Hitendra singh bhadoria
1873
Hettich Modular Kitchen in 800/Sq.Ft. only
Last answer on 11/12/2021 12:02:44 AM. by S L Gupta (Civil Engg). Forum started by JAI PRAKASH
4182
hi,i have a very small kitchen want to change into a modular kitchen can you sug
Last answer on 10/11/2020 7:17:40 AM. by Amit Hasija. Forum started by Rima_M
3739
Hi Now I am in the construction, my kitchen is 10 feet x 10 feet, your expert is
Last answer on 8/1/2018 11:35:24 PM. by S L Gupta (Civil Engg). Forum started by kannaa
3109
my kitchen is of 9 by 10 size. I want L shape modular kitchen with serving count
Last answer on 1/28/2021 10:34:37 PM. Forum started by suman
6392
Wooden Modular Kitchen versus Stainless Steel modular kitchen
Last answer on 7/3/2020 10:10:51 PM. by S L Gupta (Civil Engg). Forum started by Meenakshi
1536
7309
Modular Kitchen
Last answer on 11/30/2021 12:56:09 AM. by axelbach. Forum started by Veena Gil
2910
Last answer on 1/21/2022 6:49:43 PM. by JAI PRAKASH. Forum started by Suveera
3563
Kitchen Pictures
Last answer on 8/28/2020 2:40:10 AM. by Swati Ray. Forum started by SUTANU RANA
2177
hello,i want d designs of modular kitchen of area 9'6"*10'6"....
Last answer on 12/31/2020 2:19:10 AM. by Priti Arora. Forum started by priyanka
Modular kitchen new trends
Last answer on 3/31/2012 2:31:04 PM. Forum started by krishan
2858
modular kitchen
2797
Modular kitchen in chennai
Last answer on 2/19/2022 2:12:28 AM. by Sally. Forum started by brandoo
3457
Last answer on 2/4/2022 11:19:50 PM. by Vaasku. Forum started by jayakrishnan
2910
6818
Kitchen Ventilation
Last answer on 1/19/2022 2:55:03 AM. by sugantha. Forum started by sukamalroy
3428
Kitchen Island
Last answer on 1/5/2022 2:57:02 AM. by Mike Stanley. Forum started by tiwari_p_k
2841
Last answer on 1/5/2022 12:58:49 AM. by Misato Katsuragi. Forum started by Padmanaban
7309
Modular Kitchen
2926
Kitchen Sink
Last answer on 11/30/2021 12:21:26 AM. by Anjleen. Forum started by Sasikala R
2490
Introduction
Last answer on 10/23/2021 8:23:11 AM. by S L Gupta (Civil Engg). Forum started by davidraju
3661
Small Space Kitchen
Last answer on 9/15/2021 5:01:17 AM. by KVSN RAJU. Forum started by Shital Miriyala
2662
Thank you for all you do
Last answer on 7/19/2021 5:14:13 AM. by Amit Hasija. Forum started by raghav
2872
Kitchen Design Ideas
Last answer on 5/18/2021 7:44:04 PM. by rafi. Forum started by b.arunaseshan
2550
'island' counter in kitchen
Last answer on 1/2/2021 5:27:46 AM. by S L Gupta (Civil Engg). Forum started by Shashi Panwar
Kitchen Door
Last answer on 1/2/2021 5:22:53 AM. by S L Gupta (Civil Engg). Forum started by K. Basu
2539
Last answer on 1/2/2021 5:22:28 AM. Forum started by batambuze abdu
3348
Last answer on 12/31/2020 2:45:52 AM. by juhi. Forum started by ruchika jain
2625
How much would be the approximate cost of setting up a kitchen like this?
Last answer on 12/31/2020 2:40:21 AM. by ranjeetsaini. Forum started by debashish
3952
Last answer on 10/11/2020 7:21:30 AM. by S L Gupta (Civil Engg). Forum started by maruthi prasad
3285
Modular
Modular
Modular Office Furniture - Versatile for your Office
Having the right office furniture is very important to make office environment comfortable and as productive as possib..
Concrete Decor
Concrete Mix Ratio
Kitchen Accessories
HOW
Ready
Ready Mix Concrete
Kitchen Backsplash
