Home -> Forums -> Construction -> Ground work -> Can we use Quarry Dust for Filling the Plinth Area
Mon Feb 22, 2016Total posts : 3
K M Sendhil
K M Sendhil
Topic: Can we use Quarry Dust for Filling the Plinth Area
Dear Friends,
Can we use Quarry dust for filling the plinth are instead of Coarse Sand.
Wed Feb 24, 2016Post  #1
Dear KM
      For coarse sand see below
    Fine aggregate/ coarse sand consists of natural sand, crushed stone sand or crushed gravel stone dust. It should be hard, durable chemically inert, clean and free from organic matter, not containing any appreciable amount of clay balls or pellets and other harmful impurities i. e. alkaline, salt, mica, decayed vegetation, lumps etc.
It should be passed through I. S. Sieve 4.75 MM. It should have the finest modulus 2.50 to 3.50 and silt contents should not be more than 4%. Coarse sand should be either river sand or pit sand; or combination of the two. It should be obtained from Badarpur Sand or Stone dust obtained by crushing hard stones or gravel. It should also be obtained from river bed such as Tajewala , Dadupur sand.
Note: In general the sand particle should be coarser and have minimum silt contents. The silt contents should not be more than 4%.
Caution:
The quality of the sand has more impact on the strength of the structure inspite of the quantity of the cement used.
1) If there is more silt in coarse sand, the strength of cement mortar is reduced from 1 % to 30%.
2) If you take best quality coarse sand, it will give maximum strength.
Quality of Coarse Sand
Actual specification for the quality of coarse sand can be obtained by laboratory test but in general we can judge the quality of coarse sand in the field through the following ways.
1. Observe whether there are any lumps of earth or clay balls, grass and decayed vegetation etc. in coarse sand to check silt contents.
2. Take some samples of coarse sand in hand and observe
The particles of sand should be coarser.
Silt contents should be less
3. Take some sand in hand and drop it down
One can simply check the quality of sand by taking some sand in the hand and then dropping it down.  If some finest material sticks with hand, the sand has some silt contents and finer sand.
4. Check silts contents with the help of water
Take empty glass and put some sand and water in the glass and stir it well. After some time the silt layer will be framed between sand and water which shows the quantity of the silt contents present in the sand.
Thu Feb 25, 2016Post  #2
K M Sendhil
K M Sendhil
Thanks Sir,
Sat Mar 05, 2016Post  #3
Amazing.
2645
1393
2072
Last answer on 1/8/2018 11:06:10 PM. by S L Gupta (Civil Engg). Forum started by ravikumar
2234
Is plinth area and builtup area are same?
Last answer on 9/21/2016 12:10:11 AM. by Pawan kumawat. Forum started by hariprasad
2489
Approx.cost of construction from plinth area to completion of plastering for a12
Last answer on 12/23/2013 12:45:58 PM. by S L Gupta (Civil Engg). Forum started by neelam rathi
3830
22184
Difference between plot size area, built-up area, plinth area
Last answer on 3/17/2016 12:21:27 PM. by S L Gupta (Civil Engg). Forum started by vamsi
2957
Need suggestions
2910
3738
Designing a Foundation
Last answer on 4/1/2013 4:11:25 PM. by S Nagarajan. Forum started by cosntruction novice
7214
Alternative to river sand for wall plastering jobs
Last answer on 1/7/2011 3:36:01 PM. by jaydeep. Forum started by S. Krishnamoorthy
1706
Is there a rule such as a ratio of Plinth area to saleable area that is mandated
Last answer on 1/26/2021 10:31:37 PM. by S L Gupta (Civil Engg). Forum started by joseph
Give some proof that we have to use plinth area when both plinth area and plot area is given.
Last answer on 8/14/2014 8:23:37 AM. Forum started by vishal kumar
Give some proofs that we have to use plinth area to make plan if we have both plinth area and plot area
Last answer on 8/14/2014 8:28:46 AM. Forum started by vishal kumar
2063
concrete filling
Last answer on 4/18/2014 7:54:24 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
2260
Using MSamd slurry for filling house foundation.
Last answer on 10/26/2015 12:05:05 PM. by S L Gupta (Civil Engg). Forum started by Vinod
3129
Plinth beam at ground level
2061
treatment for white ants
Last answer on 9/20/2014 12:17:36 PM. by S L Gupta (Civil Engg). Forum started by richlyn
3925
2995
8160
software
3900
2730
1833
lanterns
3134
false ceiling
2245
about construction
1786
4154
Cement Coba
3076
Water Harvesting System
1676
1758
water tank
2058
1760
1634
Pool construction cost
1994
2738
Regarding roof beam
Fire Stair case
2645
2371
super structure
Earth Filling
Hard
Skylight
Rugs
Rugs for Living Room
Types of Cement
