Home -> Forums -> Construction -> Cement Plastering -> Can the "Gypsum Stucco Plaster" be used directly on an unplastered wall??
Fri Mar 25, 2011Total posts : 3
Amogh Desai
Amogh Desai
Topic: Can the "Gypsum Stucco Plaster" be used directly on an unplastered wall??
Hi
I have a 25 year old house constricted using Laterite Stone.  These are the kind of bricks used in goa and surrounding south indian states for cunstruction.  Can use Gypsum Stucco Plaster directly on this cunstruction without plastering the wall.???
I have attached a picture of how the wall is cunstructed (I mean it is uneven)
Attachments: walls-made-of-laterite-stone[1].jpg on Fri Mar 25, 2011,&n
Fri Mar 25, 2011Post  #1
Nikita
Nikita
Post subject: Gypsum Stucco Plaster
Hello Amogh,
Yes, gypsum stucco plaster can apply directly to internal or external backgrounds like bricks, blocks and concrete and it is suitable for various applications. It comes with some of these advantages like: fast drying, gives a smooth, white and matt finish, it can apply directly without using any primer, free from cracks etc.
Regards:
Nikita.
Fri Mar 25, 2011Post  #2
Amogh Desai
Amogh Desai
Hey Nikita,
Thanks for such a quick response.  Also, how is this priced per sq ft ??
Fri Mar 25, 2011Post  #3
Nikita
Nikita
Post subject: Price of Gypsum Stucco Plaster
Hello Amogh,
It can be between Rs.150 to Rs.200 per bag containing 25kgs. of gypsum plaster. May be changed as per there market price.
Regards:
Nikita.
Cement Plastering -Construction Questions (39)
2713
Kids room ceiling designs
2157
4210
Selection of cement ..
1408
crack on wall plaster by gypsum
Last answer on 11/22/2016 1:25:44 PM. by S L Gupta (Civil Engg). Forum started by Rizwan
4626
time for paint and wall putty
2438
Gypsum Plaster Vs S/C Plaster
1962
2523
2414
COSTING AND STRENGTH OF WALL
2924
2111
Gypsum plastering
Last answer on 7/3/2020 11:51:16 PM. by Purvi Panchal. Forum started by sanu kumar
3992
8880
7005
3841
2212
Painting interior walls
1542
POP OR GYPSUM
2533
l would like to see more gypsum designs
Last answer on 1/14/2022 3:20:41 AM. by S L Gupta (Civil Engg). Forum started by salome kapanga
3288
what material is used in ceiling other than plaster of paris?
Last answer on 6/1/2011 11:32:44 AM. by P. Panchal. Forum started by GURJEET
2929
Plaster
2781
Plaster work
3047
Plastering
1925
2005
PPC and OPC cement
11298
1871
suggest for exterior
7005
9157
1877
OPC and PPC cement
2157
2012
coarse aggregate
1826
Nice
2438
2174
Outer Plaster
2997
2735
putty work on walls
2236
2827
2033
Gypsum
Plastering
Plastering
Ceiling
Checklist for Cement Plaster
Textured
Textured Paint
Textured paint creates stunning effects on the walls of your house. It not only makes inspiring textures but also prov..
