Home -> Forums -> Construction -> Start Construction -> Cellar is good or bad ?
Fri Jun 12, 2015Total posts : 3
kishore
kishore
Topic: Cellar is good or bad ?
Hi Folks,
I have bought a plot recently approx outskirts of town and rapid growing area with a proper layout.
Plot dimensions are : 22 width * 57.25 length -- north face house
I have to build a house along with some commercial purpose which has to be used for a normal grocery shop to ware house for our textile shop or supermarket in future for this layout.
i am in view of constructing cellar (underground or basement) with total empty space so that can be used for multipurposes such as super market or textiles godown or hotel or some other needy business for this layout.
Ground floor a 2 or 3 bhk residential house.
Surprisingly, with my research in online i could find many negative responses for cellar both as per vastu or in residential area  and 2 out of 10 only said you can build cellar.
could any of you give me the detailed idea how and why not cellar can be build, if build what is the problem?
please find attached video and images of plot.
Awaiting all your answers.
Thank you in advance.
Warm Regards,
Kishore
Attachments: from north to south facing.jpg on Fri Jun 12, 2015,
east facing.jpg on Fri Jun 12, 2015,
facing west from plot.jpg on Fri Jun 12, 2015,
AubWCI58-78hxNRu_pal8L5diUKJF1oNTVVg571UF6cE.mp4 on Fri Jun 12, 2015,
south to north facing.jpg on Fri Jun 12, 2015,&n
Fri Jun 12, 2015Post  #1
Er.S.K.Jain
Er.S.K.Jain
Dear,
According Vadic vastu there is clear that the any place below road level is not preferred as per vastu.
Also it is markable when vastu shashtra come in force (First introduce in Yagurved) there is no any concept to build basement or cellar.
Basement is not prefered location for showroom as per architectural too.
Reason for not prefer cellar:
1- Basement required special attention for water proffing and ventilation.
2- In emergency escape from basemen is not fast.
3- No proper view from road.
4- You have less width of plot and ramp required half width of your plot and also required half depth of your plot.
Reason for prefer cellar:
1- No connection with residence. separate entry for cellar and residence
2- High economic value so special construction and cost is affordable.
3-Properly design for architectural needs.
4- Separate the vastu pind of residence from your cellar because vastu purush not accept cellar.
Hope you are clear now
Sat Jun 13, 2015Post  #2
kishore
kishore
Dear Jain,
Thanks for clear cut distinction.
Yes as i have very less width there are more cons compared to pros for this plot to use cellar. With the basis of all research .
Am planning to go ahead for building only ground floor upfront with half car park and remaining half for small shop and remaining back for residential house.
on top of this first floor will be built as residential . Incase if any need occurs commercially will use same first floor for business needs.
Whats your opinion on this ?
Kishore
Tue Jun 16, 2015Post  #3
1652
East face house main door exact opposite neem tree there is it good or bad
Last answer on 7/3/2020 11:47:46 PM. by JAI PRAKASH. Forum started by K.Raj Kumar
3718
My flat north , east corner wall attached lift is it good or bad .?
Last answer on 4/17/2017 12:54:32 PM. by S L Gupta (Civil Engg). Forum started by Srinivas
1252
1944
RATS PRESANTS IN SHOWROOM GOOD YA BAD
Last answer on 1/17/2012 6:21:32 PM. Forum started by KAPIL
2076
vastu guide lines for cellar
Last answer on 3/20/2011 1:25:50 PM. Forum started by DURAISWAMY.G
1779
Does under ground cellar influence families living above?
Last answer on 8/18/2011 10:58:33 PM. by D.Ramachandran. Forum started by Nagesh
2441
there is one pole in front of my house. will this have any impact on my family.i
Last answer on 7/21/2009 2:15:04 PM. by Deepti. Forum started by pc
2613
can dead person pics attached on main door or in porch it is good or bad as per
Last answer on 12/2/2021 7:24:53 AM. Forum started by UDAYKUMAR NAIK
1732
cattle shed opposite the house is good vastu or bad vastu. Pl clarify.
Last answer on 1/24/2017 1:00:33 PM. by S L Gupta (Civil Engg). Forum started by sudha iyer
2084
I want to purchase south east plot size 60ft at east side and 40ft at south sid
Last answer on 11/23/2015 11:40:03 AM. by Beenu Phogat. Forum started by RAJEEV
7407
Last answer on 7/20/2020 11:36:14 PM. by Gunjan Utraja. Forum started by srinivas
2224
New Construction
1397
I am planning to buy a residental 21*89 plot..is it good dimension??
Last answer on 2/25/2022 6:03:38 AM. by S L Gupta (Civil Engg). Forum started by KARAN KAPOOR
2625
About Rock in plot
Last answer on 12/1/2020 4:20:58 AM. by S L Gupta (Civil Engg). Forum started by madhu
759
I am looking for a good SUV for all family of middle size
Last answer on 7/9/2021 8:32:03 AM. Forum started by Simon
2911
Last answer on 1/21/2022 6:49:43 PM. by JAI PRAKASH. Forum started by Suveera
2295
Washable Paints good or bad
Last answer on 11/20/2011 11:49:18 AM. by Amit Hasija. Forum started by raghuam
1484
Plot near lake good or bad ?
Last answer on 7/30/2014 11:20:54 PM. Forum started by rukepedia
3312
2312
Tips for Cement Paint
Hotel
Hotel lobby lighting
Lighting plays a pivotal role in an eye-catching hotel lobby. Lobby lighting is a special challenge for designers.
