Ground work
Cement Coba
Cement Coba
Tue May 26, 2015
Prasenjit
Topic: Cement Coba
I have a bunglow in my native place. There is 900 sq. ft. open place near my Bunglow. Please give information to me what is the cost of cement coba per sq. ft. and what is the cost of paver blocks per sq. ft. with labour cost and without labour cost.
Thank you.
Wed May 27, 2015
They are available on per piece basis, starts from 10 to 50 Rs/pc depends iupon the size and design and colour, installation labour rate is same as of floor tiles.
Ground work-Construction Questions (38)
2298
Last answer on 9/29/2014 12:34:55 PM. by
Sanjay Gupta
3122
Last answer on 8/27/2015 6:46:22 PM. by
please tell me the procedure of bb.coba for terrace waterproofing and please sug
Last answer on 8/24/2020 10:18:48 AM. by
3792
Last answer on 9/21/2020 2:27:35 AM. by
krishna
1923
Last answer on 10/15/2015 2:13:06 AM. by
prasad K
2410
what are these 3 types
Last answer on 7/4/2020 2:25:50 AM. by
sushantsah
2696
Last answer on 7/16/2020 11:56:35 PM. by
RAVISHANKAR
4212
Selection of cement ..
PRAVEEN G
1767
vishal Thakur
1460
vishal Thakur
1659
Last answer on 7/15/2017 12:48:17 AM. by
Frank lun ngaihte
3075
Last answer on 2/9/2010 4:02:40 PM. by
Nisha
1742
Last answer on 5/25/2016 11:08:08 AM. by
Dev
2123
I have read your articles regarding the strength of fresh cement,and how cement
Last answer on 9/13/2012 5:19:43 PM. by
George Kattapuram
2405
Last answer on 2/26/2013 11:22:44 AM. Forum started by
nasad
2120
Difference b/w company and factory manifectured cement
Last answer on 2/22/2013 11:30:32 AM. by
Last answer on 11/8/2017 2:30:27 AM. by
Rajesh
2276
swarup chakraborty
2967
Tips for Cement Paint
Last answer on 12/31/2020 1:53:47 AM. by
yespeeyen1952
eduard
2998
Karan
8161
software
Vaasku
sco4666
sagar suryawanshi
2730
Manish Singh
1833
lanterns
ARVIND GOYAL
3134
false ceiling
sabita laskar
2245
about construction
simran
1787
lowz
3077
Water Harvesting System
sunny420
1677
Robert
1758
water tank
rodmotall4
sadanand
2059
sumit
1761
jitendra kumar
1634
Pool construction cost
Erling
Shardul
1996
sanyindias
2738
Regarding roof beam
Amit Kumar
Fire Stair case
mvxmanazxmfsm
tejas
2646
MOHD WAKEEL
2374
super structure
anil kumar
Cement Concrete Raw Material
Read points should be kept in mind while collecting raw materials for cement concrete in construction work.
Types of Cement
