Cement
Cement selection
Cement selection
Wed Apr 29, 2015
ashuu
Topic: Cement selection
Iam starting house construction confused about which cement to use
PPC (ACC or other brands) or OPC 43/53 Brila Super/Ultratech
kindly guide me...
Wed Apr 29, 2015
Brand doesn't matter, go as per the grade only.
Sat May 02, 2015
Hi Ashuu: For house construction, go for PPC 43 grade cement. Absolutely no need for 53 grade. PPC cement, containing fly-ash, gives you more time to work with wet cement as it has a longer setting time and gives more compressive strength with the passage of time when compared to a OPC cement. Brand is as per your budget, availability and choice.
I hope it helps.
Sun May 03, 2015
2308
Cement selection
Last answer on 10/31/2012 10:53:57 AM. by
amzad
amzad
1931
Last answer on 11/14/2015 12:48:34 AM. by
prasad K
4212
Selection of cement ..
PRAVEEN G
543
A trustworthy torrent site - which one to pick?What are the selection criteria?
Last answer on 1/5/2022 9:16:55 PM. by
olii fill
CrySmile
1697
what should be the criteria for selection of house in a society, should one go f
Last answer on 12/31/2020 2:12:04 AM. by
Priti Arora
puneet
3792
Last answer on 9/21/2020 2:27:35 AM. by
krishna
1923
Last answer on 10/15/2015 2:13:06 AM. by
prasad K
2410
what are these 3 types
Last answer on 7/4/2020 2:25:50 AM. by
sushantsah
2695
Last answer on 7/16/2020 11:56:35 PM. by
RAVISHANKAR
1767
vishal Thakur
1460
vishal Thakur
1659
Last answer on 7/15/2017 12:48:17 AM. by
Frank lun ngaihte
2405
Last answer on 2/26/2013 11:22:44 AM. Forum started by
nasad
3075
Last answer on 2/9/2010 4:02:40 PM. by
Nisha
2123
I have read your articles regarding the strength of fresh cement,and how cement
Last answer on 9/13/2012 5:19:43 PM. by
George Kattapuram
1742
Last answer on 5/25/2016 11:08:08 AM. by
Dev
2909
Shuttering Plywood
Last answer on 11/17/2009 9:26:16 AM. by
Girish
Girish
2967
Tips for Cement Paint
Last answer on 12/31/2020 1:53:47 AM. by
yespeeyen1952
eduard
2082
Last answer on 10/23/2010 3:33:17 PM. Forum started by
sandeep Dholakia
1670
Cement requirement
Last answer on 1/5/2022 12:58:42 AM. by
Yousuf
1785
RAW MATERIAL
Last answer on 9/20/2021 1:41:45 PM. by
sumit
3443
Type of Cement
Last answer on 4/22/2021 5:20:49 AM. by
sumit dua
2528
RCC Slab -Curing
Last answer on 3/25/2021 4:28:26 AM. by
Arvind Bhaskar
2327
Materials
Last answer on 3/2/2021 6:29:44 AM. by
UMinesh
23820
Last answer on 2/17/2021 4:49:34 AM. by
2873
Types of Cement
Last answer on 12/31/2020 2:12:10 AM. by
Sonika
shivakumar
2515
Cement
Last answer on 7/2/2020 10:15:16 PM. by
ferous
2737
Per Square
Last answer on 6/23/2019 11:56:29 PM. by
kiran kumar 3k
1284
Last answer on 11/2/2016 11:29:57 AM. by
1990
Cracks in concrete roof
Last answer on 8/24/2016 4:18:27 PM. by
Dhanush Ahuja
Aarav Sharma
1242
Last answer on 5/26/2016 12:44:58 PM. Forum started by
SUNIL KUMAR
1742
Dev
1876
Economical cement brand
Last answer on 2/22/2015 7:02:19 PM. by
Bhuwan
Bhuwan
2906
Cost of Cement Plaster
Last answer on 6/4/2014 11:32:31 AM. by
Subhajit Kundu
1858
Last answer on 4/11/2014 2:04:43 PM. by
shaik khaja nayab rasool
2485
Cement and Grades
Last answer on 6/13/2013 2:45:08 PM. by
MANJUNATH
3041
Last answer on 3/19/2013 12:28:05 PM. by
HARISH
2437
Past Prices
Last answer on 11/23/2011 10:23:47 AM. by
ravi at Dalmia
Hemanth
How to select Mason
For all type of construction, weather new or alteration, Mason is a very important and selection of a mason is not a b..
Selection of Cushion Covers
Cushion covers are a great bonus to the interior of a home. They cover up your cushions and can superbly change the lo..
Types of Cement
