Cemmet Propotion for ceiling
Mon Jul 20, 2015Total posts : 5
vijay
vijay
Topic: Cemmet Propotion for ceiling
My contractor used cement : sand : aggregate (20mm) in the proportion 3 : 8 : 9. I am not sure if it is strong enough. Can you please reassure if it is not going to collapse on my head :-(
Vijay G
Mon Jul 20, 2015Post  #1
Various Ratios of RCC
RCC denotes Re-in forced Cement Concrete in which cement, sand and Bajri are laid with the help of mild steel. This is most important part of the structure. Generally 1:2:4 and 1:1.5: 3 ratios of RCC are used in construction work.
RCC 1:2:4
Where cement concrete 1:2:4 is used; it means 1 part of cement 2 parts of fine aggregate/coarse sand and 4 parts of coarse aggregate. This ratio of cement concrete gives high strength of cement concrete and is recommended for following works.
• For general RCC work in buildings
• Bed plates
• Lintels
• RCC shelves
• Pavement etc.
RCC 1:1.5:3
Where cement concrete 1:1.5:3 is used; it means 1 part of cement 1..5 part of fine aggregate/coarse sand and 3 parts of coarse aggregate. This ratio of concrete also gives very high strength of cement concrete and is recommended for following works.
• Structure carries in heavy loads
• Important RCC structure such as columns, beams, slabs, cantilever, Chhajja, porch, and balcony etc.
• Minimize the effects of earth quake.
• Gives more strength accordingly if Tor or Ribbed steel is used with cement concrete 1:1.5:3.
Tue Jul 21, 2015Post  #2
vijay
vijay
Post subject: Need confirmation
Hi Jai Prakash,
thanks for your response. I was able to get similar data from internet. But i am looking for re-assurance with the propositions we used. will it be strong enough for residential purpose.
vijay G
Tue Jul 21, 2015Post  #3
Er.S.K.Jain
Er.S.K.Jain
the proportion 3 : 8 : 9 means it is 1:2.67:3
The proportion required to set as per design mix by lab test or by experience to achieve required strength
Your proportion like empirical mix when the grit size is over size than 20 MM and also sand are more coarse than required.
in general in uttar pradesh we use 1:2:3 and in some case when more smoothness and flow of concrete required with more coarse sand and over size grit some contractors use 1:2.5:3
it is not bad and hope to get desired strength of M20
Better if you check with structural designer who design your building with the sample of sand and grit or by lab test of cube test if possible.
if spans are under 12'-0" x 12'-0" and thickness of slab is minimum 4.5" no need to worry.
Tue Jul 21, 2015Post  #4
Please go ahead. Do not worry.
Tue Jul 21, 2015Post  #5
vijay
vijay
Post subject: Thanks for the assurence.
i have the ceiling idea now i want to draw the ceiling plan and terminology to
Last answer on 4/23/2021 2:07:42 AM. by S L Gupta (Civil Engg). Forum started by moksha
1572
wiring run above ceiling
Last answer on 6/20/2016 12:13:42 PM. by SW Psychology. Forum started by krish
2729
2332
the ceiling is perfectly made,but the lighters are too many on the ceiling,makin
Last answer on 11/11/2010 10:07:30 PM. by dinesh sharma. Forum started by AMBROSE MASINDE
2980
Last answer on 12/31/2020 2:26:35 AM. by rajendrakumar. Forum started by mary cecil
2309
i want to see different type of POP on ceiling
Last answer on 12/31/2020 2:33:42 AM. by jaydeep. Forum started by radheshyam
3657
Living Room Ceiling
Last answer on 2/9/2021 5:22:05 AM. by Hikkler. Forum started by sheaikh mohd abid
3126
Dining Room Ceiling
Last answer on 7/2/2020 8:51:19 PM. by O'SirTee. Forum started by atiq khan
can you tell me how much cost goes for galaxy ceiling decoration
Last answer on 5/2/2010 8:37:50 AM. by Ajit Tareeka. Forum started by Rahul S Chopade
2724
could you send me some more good designs not satisfied with this type of pop cei
Last answer on 6/23/2021 6:18:33 AM. by Richa Shangvi Interior decorator. Forum started by maya
2963
i want desings of fall ceiling in apartment flat
Last answer on 3/12/2021 10:49:40 PM. by G N Shaikh. Forum started by shrenik
2237
WHAT IS THAT RED CEILING MAD OF
Last answer on 11/29/2010 8:18:20 AM. by mahima. Forum started by EARLJAC
2391
how can i do my ceiling
Last answer on 3/31/2011 8:54:13 AM. by Nikita. Forum started by sadekhussin
1570
what is that ceiling can i have info about it
Last answer on 4/5/2011 1:07:00 PM. Forum started by sbalushi
3722
i am looking forward for a book of interiior designing preferably wth pictures o
Last answer on 7/3/2020 11:11:57 PM. by Nikita. Forum started by ravi
4099
false ceiling design needed for bedroom
Last answer on 2/17/2022 3:35:09 AM. by JosephCarlo. Forum started by chandru
3265
nice ceiling drawing
Last answer on 1/13/2022 12:01:18 PM. by Karan Kundra. Forum started by deepak
10898
how much will it cost to construct a false ceiling
Last answer on 9/15/2021 9:50:00 PM. by ravi at Dalmia. Forum started by Vijayaraj
2759
plz send some circular ceiling designs in modern theme
Last answer on 7/1/2021 5:42:04 AM. by S L Gupta (Civil Engg). Forum started by arpit
30
Boyfriend/Girlfriend Vashikaran Specialist Tantrik Baba Ji 91-9056562757
Last answer on 1/6/2025 11:00:11 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:10 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:09 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:08 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:07 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:06 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:05 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:04 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:03 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:02 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:01 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:00 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 10:59:59 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 10:59:58 PM. Forum started by Pandit Sahil Sharma Ji
Dining
Dining Room Ceiling
How to clean plaster ceiling?
Kids
Kids room ceiling designs
Ceiling
Living Room Ceiling
Ceiling
Ceiling Lighting
Ceiling
Ceiling Fans
Basement Ceiling
Ceiling
Ceiling designs
