Home -> Forums -> Construction -> Layout and House Plans -> Check the load
Check the load
Mon Nov 11, 2013Total posts : 2
Dilip
Dilip
Topic: Check the load
Hi Experts,
We had constructed a house 4 years back(30 X 41 ft).It had a single double bed room house with car parking in ground floor and then 3 single bedroom houses in first floor and second floor each.It had a single bed room house in the 3rd floor(300 sq ft).
We have 12+1+1(14) pillars in the ground floor and 12+1(13) pillars runing all the floors.The dimension of pillar is 15 inch / 6 inch.
Last year we constructed 2 more houses in the 3rd floor similar to 1st and 2nd floors. While constructing we used only 2 pillars which were left for extension with the 6 pillars which were already used by the single bed room house.
Just want to know if the pillars are able to sustain this load..
Thanks in advance..
Tue Nov 12, 2013Post  #1
Dear Dilip
        The strength of column/ pillar depends on the size of pillar, MS steel bars used in the pillar and ratio of cement concrete used in the pillar.
The foundation of pillar also to be taken in account while designing the pillar for the load coming on it.
 The loading is depend upon the span of the pillar i.e. distance between pillars in both  ways.
It is advisable to take help from local civil engineer , who can give advice after inspecting the house.
Sun Nov 17, 2013Post  #2
Dilip
Dilip
Thanks for your reply sir..the size of the pillar is 15x6 inch..I dont know the exact size of ms steel bars and cement ratio being used.
Each pillar is at a distance of 10ft from each other on one side and 11 ft from each other..A total of 12+2(14) pillars in grand floor and 13 pillars extending further..
Could you pleas advice based on your vast experience.,
Thanks...
10047
2762
3608
1941
Last answer on 5/24/2012 5:08:53 PM. by S L Gupta (Civil Engg). Forum started by gaju
1881
check this
Last answer on 7/14/2010 6:48:24 PM. Forum started by nayma
1902
point to be check befor tile application
Last answer on 9/12/2013 12:12:08 PM. by S L Gupta (Civil Engg). Forum started by archi
857
Last answer on 1/27/2022 6:31:12 PM. Forum started by Rahul T Pal
7257
2616
COLUMN nd LOAD BEARING
2092
Taking Possesion
Last answer on 11/10/2010 4:50:48 PM. by Nitin Iyer. Forum started by Nitin Iyer
2703
home security systems
Last answer on 7/3/2020 10:55:36 PM. by S L Gupta (Civil Engg). Forum started by farrukh tahir
2186
Commeriacal interior
Last answer on 12/21/2021 8:32:17 AM. by leelindsey. Forum started by sandeep yadav
2115
Structure proof checking
2218
Company and Cost of Solar panels for 3 storey building
Last answer on 7/3/2020 9:55:28 PM. by S L Gupta (Civil Engg). Forum started by sowmya
7927
3005
i wana construct a 18X14 feet hall single story .Is 9x9 column at corner os suff
Last answer on 9/19/2013 2:12:08 PM. by manishkumar. Forum started by manishkumar
3424
3941
2256
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2241
3595
2324
2090
2792
1548
2114
Check width and depth of the channel, the quality and size of the bricks for mechanical protection.Whether cable ident..
Specification of Steel
Checklists for Doors and Windows
Doors and windows are costly item in house construction and it provides safety, ventilation and adds the beauty and lo..
10 things to check before the rain hit your home!
Rain is fun but the fun may not last if your home fails to protect itself and its occupants from the elements. This wr..
