Home -> Forums -> Construction -> Flooring -> Checklists for flooring
Tue Mar 31, 2015Total posts : 4
MUTHU
MUTHU
Topic: Checklists for flooring
advice me what kind of flooring is suitable for house construction
The comment above talks about the article   "Checklists for flooring"
Tue Mar 31, 2015Post  #1
First select the flooring as per your budget like Granite, Marble, Kota, Tiles wooden etc then checklist later.
Wed Apr 01, 2015Post  #2
himanshu
himanshu
The flooring used in the house should be durable, long lasting and non - slippery.
Fri Apr 03, 2015Post  #3
Dear Muthu
             As stated by Sh Himanshu flooring should be durable, long lasting and non-slippery and within budget See the link below
http://www.gharexpert.com/articles/Flooring-1496/Appropriate-Flooring-different-Locations_0.aspx
Sat Apr 04, 2015Post  #4
Flooring-Construction Questions (19)
3032
What is the checklist for wooden doors?
Last answer on 3/13/2010 8:35:00 PM. by K Anjaneyulu. Forum started by vijaykumar
3382
Checklist for Painting Work
Last answer on 9/26/2011 12:10:51 PM. by dharmalingam. Forum started by vikram khot
1919
2372
1597
How much Marole required
3947
need for plan
2467
1949
please send me 55 feet by 58 feet plans,graund floor and first floor
Last answer on 4/29/2015 11:56:29 AM. by seema tyagi. Forum started by Hafiz Abdul
1767
3382
3162
plz send me vastu complaint floor plan for 2 floor plot having dimensions of 30"
Last answer on 2/21/2022 6:22:21 AM. by seema tyagi. Forum started by ashok
2397
is it advantageous to buy flat with stilt 2 floors or stilt 4 floors
Last answer on 7/29/2014 12:12:50 PM. by S L Gupta (Civil Engg). Forum started by Jacob Alex
2029
Last answer on 5/13/2014 11:34:16 AM. by Ahmed. Forum started by bansalanil96
3347
2065
We have a Ground floor house already constructed some 15 years ago,and 2 floors
Last answer on 8/22/2013 10:36:36 AM. by S L Gupta (Civil Engg). Forum started by feroz khan patthan
1537
Dear Sir, I have almost completed 1st floor and the second floor residence.the g
Last answer on 1/20/2022 1:31:30 AM. by S L Gupta (Civil Engg). Forum started by Chandrasekaran S
1864
Extension of floor area in 1st floor
Last answer on 4/21/2015 10:48:31 AM. by seema tyagi. Forum started by ds
2378
Spiral staircase from first ground floor to first floor
Last answer on 3/4/2015 12:37:11 PM. by satish. Forum started by satish
Checklists for Doors and Windows
Doors and windows are costly item in house construction and it provides safety, ventilation and adds the beauty and lo..
Checklist for Plumbing
Checklist for Cement Plaster
Check width and depth of the channel, the quality and size of the bricks for mechanical protection.Whether cable ident..
Checklist
Terrazzo
Drawing
Drawing Room Flooring
