Home -> Forums -> Construction -> Foundation -> Choosing the right type foundation and structure for house
Fri Sep 30, 2011Total posts : 1
Vinod
Vinod
Topic: Choosing the right type foundation and structure for house
I am planning to build a two storey house of 2000sqft, 1000+1000, in a rice field area being developed into residential area. The two storey houses around my plot are built upon rubble foundation upto 2.5m deep from ground level. ie. Rubble foundation + Concrete belt + Wall + Lintel + Wall + Concrete roof.
After going through the advices here, I think, I don't need to go for pillar foundation as the rubble foundation works up to 3m. But, any advantage if  I go for curtain wall structure ie. Beams between Belt and Lintel at all corners of all rooms so as the walls don't bear any load. Does it provide additional safety in case of earthquake? I want to provide earthquake resistance to my house within budget. So, please advice.
Tue Oct 04, 2011Post  #1
Dear Vinod
    For constructing earth quacke safe house you should go through the website gharexpert.com construction section in which you find safty sub section where in earth quacke saftey you will find lot of materia about construction. some link given below.
http://www.gharexpert.com/articles/Earthquake-2082/Earthquake-Resistant-Building-Construction_0.aspx
http://www.gharexpert.com/articles/Earthquake-1461/Make-your-home-earthquake-proof_0.aspx
http://www.gharexpert.com/articles/Earthquake-723/Which-type-building-materials-construction_0.aspx
1065
2750
1827
foundation
Last answer on 10/5/2014 1:20:44 PM. by SANJAY DUSANE. Forum started by nitu
4928
LOAD BEARING STRUCTURE
1893
column STRUCTURE
Last answer on 11/9/2015 3:11:28 PM. by S L Gupta (Civil Engg). Forum started by DURJOU KUMAR MONDAL
2410
what are these 3 types
1256
2213
2617
COLUMN nd LOAD BEARING
2322
2957
Last answer on 8/1/2012 9:53:21 AM. by Ravi. Forum started by J J Gupta
3505
Last answer on 11/8/2021 10:59:52 AM. by nehamehta. Forum started by J J Gupta
3880
2269
Please tell me 15*46 right 2bhk house plan
Last answer on 7/3/2020 10:35:21 PM. by S L Gupta (Civil Engg). Forum started by Roshan mallya
9198
2770
Compound wall construction
Last answer on 11/5/2014 9:02:10 PM. by SANJAY DUSANE. Forum started by Mahesh
1835
Hi ,I need to build compound wall for area of 12ft high and 40ft length 9 inches
Last answer on 11/3/2014 11:39:50 AM. by S L Gupta (Civil Engg). Forum started by Mahesh
2188
I plan to start new house, which type of foundation is best for home.1.asthivara
Last answer on 4/4/2015 1:14:31 PM. by S L Gupta (Civil Engg). Forum started by ananth
2684
Pillar
2140
Curing urgent
2373
structure work
5166
Pillar foundation
2204
new house
2821
building a house
1992
Construction Agreement
3091
Foundation
2273
Foundation
1477
10048
3661
Foundation
2115
Structure proof checking
2558
Foundation design
2462
2469
Saria and cement
3657
Wall Thickness
2679
3180
13268
Steel Type
Designing
Designing a Foundation
What do colors represent? How do they enhance the look of the room?
White (and its various forms such as off-white, beige, and eggshell) is popular and an all time favorite choice. It ca..
Basic rules while designing the light.
Every activity that takes place in the interior must have lights of the right kind, intensity and the right direction.
Right size cupola
