Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Column Bars Specifications Reqd
Tue May 31, 2016Total posts : 3
Pankaj Varshney
Pankaj Varshney
Topic: Column Bars Specifications Reqd
We are constructing a G+4 Building with 16nos of 9X9 columns with 4 bars of 16mm and 2 bars of 12mm and stirrups of 8mm.
Is it enough or shall i replaces the 12mm bars with 16mm one.
construction going on 1st floor.
Wed Jun 01, 2016Post  #1
Dear Pankaj
         For 5 story building, in my view take structure design. The size and numbers of columns,  MS Steel bars are calculated with the structural drawing according to loading condition, safe bearing capacity of soil and effect of earth quack etc. As you say 16 nos column for what area and at what distance and for what load these column to bear. The size and MS steel given is on inadequate or on lesser side.
Wed Jun 01, 2016Post  #2
Pankaj Varshney
Pankaj Varshney
Sir, it is a 900 Sqft area with 28X32 ft size.
the max span of the column is 11 ft whereas min in 6ft.
A total of 16 columns are there interconnected each other via Tie Beam.
Foundation depth was 6ft.
your expert views are awaited.
Thu Jun 02, 2016Post  #3
Dear Pankaj
         As I already stated that take proper structural design. You are spending Rs 70-80 lac for construction of 5 story building it is better to spend some thousand on design for structure safety and design can save construction cost as without design one use more quantity in fear. No one can take responsibility without design for giving expert view. Expert view can be given on proper design not on hit and trial method. See some links for construction
13774
overlap length to steel
2037
2708
2304
2035
2899
RCC Roof
3510
8965
Last answer on 9/11/2020 2:17:26 AM. by hemant. Forum started by hemant
2539
5666
Column and beams specification for 5-7 floor house
Last answer on 8/7/2011 5:52:06 PM. by timm todd. Forum started by timm todd
2144
About column and beam structure
Last answer on 1/4/2019 11:39:23 PM. by S L Gupta (Civil Engg). Forum started by Rana kachari
2260
m15 cost vs m20 cost
2861
Column Size and distance
3059
steel formula
Last answer on 4/16/2014 8:05:15 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
2121
underground water tank
2957
Need help for terrace room to cover iron bars (Picture Attached)
Last answer on 12/28/2012 11:27:53 AM. by S L Gupta (Civil Engg). Forum started by prabhjeet
10903
Last answer on 2/8/2021 2:14:37 AM. by John. Forum started by karthik
5812
3793
9886
2670
4628
4143
2867
5008
3658
1865
2801
2610
2374
2464
2638
1809
3608
6254
HSD
Type
TMT
Dining
Dining Chairs and Bar Stools
