Home -> Forums -> Construction -> Cement Concrete -> Column and Frame Structure Building
Sun Jul 26, 2009Total posts : 13
cosntruction novice
cosntruction novice
Topic: Column and Frame Structure Building
I am getting a first floor added to my house. I had engaged an architect but he has delivered only corportaion drawing and is asking for a supervision contract before he delivers structural drawings etc. Are these needed? My contractor says no need
The comment above talks about the article   "Column and Frame Structure Building"
Mon Jul 27, 2009Post  #1
Priti Arora
Priti Arora
Post subject: Structural drawings
Dear sir
It is not necessary to give supervision contract to architect. It is either up to you to supervise your work your self or by any other person. If you still have difficulty in getting structural drawing, you can hire the structural engineers from our web site by sending plan of your proposed house.
Priti
Wed Dec 16, 2009Post  #2
Amar Singh
Amar Singh
Post subject: Column and Frame Structure Building
Nos. of colums for a house as per vastu
Tue Feb 02, 2010Post  #3
imtiyaz hussain
imtiyaz hussain
The longitudinal reinforcement in columns should be properly staggered.
Tue Feb 02, 2010Post  #4
imtiyaz hussain
imtiyaz hussain
The longitudinal reinforcement in columns should be properly staggered. What should be the cost of construction which includes concrete+manpower+shuttering etc.
Thu Sep 16, 2010Post  #5
Rajkumar
Rajkumar
how can a calculat building load
Sun Mar 13, 2011Post  #6
R.SHANMUGAM
R.SHANMUGAM
what is the size RCC foundation for erection of 6m ht of 300MM I sections for road gauging purpose
Tue Aug 28, 2012Post  #7
faruk
faruk
thanks every body,,,,
Tue Sep 30, 2014Post  #8
D.CHANDRAKANT
D.CHANDRAKANT
I have a ground + 1 floor house on 160 sq yards area. It is built up on basement. I wish to extend the front portico of 1st floor from present 2 ft long to 5ft more. I wanted to know is it possible ?whether I need to put any new pillars supporting the extra space ? Second question - Is it possible to construct a one room on top floor. Or I need to take help of structural engineer for this ?
Tue Oct 14, 2014Post  #9
RANDHIR KUMAR GUPTA
RANDHIR KUMAR GUPTA
what should be the size of coumn for 12'length and 14'breadth size room? please suggest any website for reference. thank you.
Thu Oct 23, 2014Post  #10
R.C.PANDEY
R.C.PANDEY
how much cost may be required to build column 14 nos beams roof per sq.ft.
Tue Jul 07, 2015Post  #11
Ganesh
Ganesh
Sir, I need to construct 30 X 25 = 750 Sft plain Rooms of 3 floors (G + 2) What is Stell sizes and How much stell required for me Beam Sizes Column Sizes Slab Sizes and total weight of the Steel please help me with information
Cement Concrete-Construction Questions (39)
2221
2621
COLUMN nd LOAD BEARING
2303
RCC Framed Structure: Sequence of constructioin
Last answer on 12/27/2014 3:22:06 PM. by S L Gupta (Civil Engg). Forum started by Arvind Bhaskar
2263
14618
1748
1766
2750
3800
4942
COLUMN AND STEEL DESIGN
4942
2071
beam and column
2843
how to make footing and column for g 2 building on water well
Last answer on 4/1/2013 7:09:40 AM. by Arun. Forum started by Arun
2039
construction of second 7 third floor
Last answer on 1/2/2013 11:45:31 AM. by S L Gupta (Civil Engg). Forum started by kiran kumar 3k
3664
1880
Column and width of the Room
Last answer on 12/8/2014 11:53:31 AM. by S L Gupta (Civil Engg). Forum started by Arvind Bhaskar
5231
2738
3474
Cost of concrete walls
1800
STP
3112
3656
4351
rate comparison
3210
Concrete Mixture
3147
sloping roof
2095
15849
6477
2387
leakage in new slab
1534
Guide me
5150
2541
Civil Eng Stair Design
2541
2338
Related to Sunken Slab
1862
2002
Concrete Hollow Block Masonry
2424
roof concrete
3202
Ready Mix Concrete
Earthquake
Door
Door and Window Frames
Orientation
Orientation of Building
Teak
Teak wood frame
