Foundation
Tue May 19, 2015
Wiki
Topic: Column Size suggested by structural engineer
I am gonna construct a commercial plot having size 35 *55..Now i am gonna construct basement ground and first floor though i want it to be designed for 5 floors like maybe in future,My structural engineer recommended 12*12 column size with each column having 0.75 inch 6 steel bars .do you think is it the right size for a column .total no of columns are 15 or 16.Also his designed footing for the columns is 4*4 ft.is this footing enough??
Tue May 19, 2015
Dear Wiki
From your question I under stand that the design given to you by structural engineer is for basement,ground and first floor. Now you want design for 5 floors. You should contact your structural engineer for revision of drawing design.In my view the present design is not for 5 stories.
Tue May 19, 2015
Wiki
No sir structure engineer says that this design is for 5 story building.but i doubt it.i am confused should i go with it or check with some other reputable engineer.plz suggest me what to do...and also is there any need of raft foundation though soil analysis is fine...
Tue May 19, 2015
The suggestion doesn't seems to be ok for 5 floor building with basement. Its lesser even for a 2-3 floor building. Please change as per the guidelines.
3794
Last answer on 12/2/2014 12:34:34 PM. by
hemant
6440
Column placement for house
Last answer on 9/13/2017 11:49:12 PM. by
sanjay singh
Parmeswar Giri
4939
COLUMN AND STEEL DESIGN
Last answer on 1/9/2021 12:01:44 AM. by
Kaleemullah
4939
Kaleemullah
4650
Last answer on 11/10/2014 2:26:39 PM. by
hemant
2197
Usage of M-Sand in Bangalore
Last answer on 3/8/2021 5:46:19 AM. by
Rajiv
3017
Last answer on 6/22/2017 11:07:36 PM. by
Anshu
15780
Last answer on 12/8/2014 6:14:14 PM. by
Deep Shrestha
Deep Shrestha
9002
Last answer on 2/15/2015 10:53:28 PM. by
Raymond
ringwang
R.Roy
1245
Hello all,I follow you for improving my knowledge. I want help in columns size o
Last answer on 8/8/2017 11:55:23 AM. by
poojathakraan
poojathakraan
Column sizes for Individual House with G+2 design
Last answer on 7/12/2016 1:46:04 PM. Forum started by
Venkat
1966
Dear Sir,Can you please tell me the size of the column and footing for individua
Last answer on 11/25/2020 5:27:11 AM. by
Venkat
Venkat
3134
Last answer on 12/17/2020 11:30:34 PM. by
deepu
8965
Last answer on 9/11/2020 2:17:26 AM. by
hemant
hemant
2320
Overhead water tank design
Last answer on 10/26/2016 12:48:05 PM. by
Rakesh
2016
Regarding construction
Last answer on 1/2/2021 5:22:59 AM. by
muchbusy
AKASH SINGH
2243
Last answer on 7/4/2020 12:04:58 AM. by
ringwang
1635
My plot size is 15*45 ,East facing , please suggest plan for G 2 .
Last answer on 1/19/2017 11:27:16 AM. by
Dev
2684
Pillar
Last answer on 2/24/2022 11:04:22 AM. by
keshavthakur
2140
Curing urgent
Last answer on 2/23/2022 5:17:08 PM. by
Rohit Sharma
Pooja
2371
structure work
mamtagarg
manish agarwal
5166
Pillar foundation
Last answer on 2/1/2022 10:02:34 AM. by
joe kurian
joe kurian
2202
new house
Last answer on 1/5/2022 2:13:15 AM. by
Janette
ananth
2821
building a house
nashir
1990
Construction Agreement
Last answer on 12/21/2021 12:56:56 AM. by
Abhijit
3089
Foundation
kamal
2272
Foundation
Last answer on 12/20/2021 6:20:53 AM. by
Gagandeep
1476
Last answer on 11/13/2021 8:11:49 AM. Forum started by
passwordc
10047
manishkumar
manishkumar
3660
Foundation
Rohit Sharma
2115
Structure proof checking
Arnab Ghosh
2558
Foundation design
DavidFlores18
nithun
2459
Last answer on 5/22/2021 11:37:00 PM. by
mayowa
2467
Saria and cement
Last answer on 3/25/2021 4:28:11 AM. by
ARVIND GOYAL
3656
Wall Thickness
Last answer on 12/31/2020 2:31:58 AM. by
shankar
2676
Last answer on 7/28/2020 12:37:29 AM. by
K M Sendhil
3179
satya
13266
Steel Type
Last answer on 7/4/2020 2:48:38 AM. by
erbharathi
sumit dua
Right size cupola
What is binding wire
