Sat Jul 14, 2012Total posts : 1
George Kattapuram
George Kattapuram
Topic: Column casting along with retaining wall has been done using stone bricks as shu
Column casting along with retaining wall has been done using stone bricks as shuttering by my contractor (from footing t0 3 feet height). He removes the shuttering stone blocks after 4 hours saying that the column concrete has started to set, and it is ok to remove the blocks. He agrees that for further column casting he will use wooden shuttering.... Will this initial column casting method affect the column strength in any way?. Should I stop work as ask him to using proper wooden shuttering or Centering Sheets?Pls Advise..George
Mon Jul 16, 2012Post  #1
Dear George
            The shuttering should be water tight, strong enough to take the pressure from concrete. It should be strong that take pressure from vibratery forces when we vibrate the concrete mix.. See link below for proper shuttering work/ form work.
http://www.gharexpert.com/articles/Cement-Concrete-1753/Centering-Shuttering--Form-Work_0.aspx
2309
Stone on elevation
Last answer on 9/23/2015 11:38:20 PM. by sanjay agarwal. Forum started by rishabh
9195
892
My home is 3 floor, ground Plus 2 floor. But built up with 4" brick walls along
Last answer on 7/3/2020 9:43:54 PM. Forum started by Rohit Kumar
3155
Basement waterproofing
3508
3456
5134
Use of Solid Concrete Bricks
3713
exterior walls
5663
Column and beams specification for 5-7 floor house
Last answer on 8/7/2011 5:52:06 PM. by timm todd. Forum started by timm todd
4209
Selection of cement ..
2835
Compound Wall Construction
13650
2865
Bricks
3992
2645
2413
COSTING AND STRENGTH OF WALL
1778
2590
a plot having road from south meets the plot at ES corner and moves along SW cor
Last answer on 8/22/2014 10:19:25 AM. by seema tyagi. Forum started by LULU
Appropriate
Garden
Garden Path Ideas
Hard
