Home -> Forums -> Construction -> Start Construction -> Column size and distance between column
Mon Dec 08, 2014Total posts : 2
Deep Shrestha
Deep Shrestha
Topic: Column size and distance between column
I would like to kindly request for your advice on attach house map whether it is appropriate or not as column size and distance between column.
Thank you,
Attachments: Ground Floor Plan.jpg on Mon Dec 08, 2014,&n
Mon Dec 08, 2014Post  #1
Dear Deep
           Marking of columns  and size of columns on the plan seems to be correct.
Mon Dec 08, 2014Post  #2
Deep Shrestha
Deep Shrestha
Dear Mr. Gupta,
Thank you for your quick response, some of neighbor suggesting to have one more column between second row as it is 17 feet plus wide, is it necessary? What we should have necessary on top such as beam? Certain level of slab’s thickness?
As on ground floor I will have living room, and I don’t want to be pillar at middle so we have only two pillars on first and second row is it ok?  Your valuable advice play vital role for us to plan further.
Thank you,
3801
2724
6566
9027
6468
Column placement for house
3028
2105
3515
2867
Column Size and distance
8971
Last answer on 9/11/2020 2:17:26 AM. by hemant. Forum started by hemant
5220
3940
For G 2 residential building, column size 9"*15",16mm 4rod,12mm 2rod used.. hori
Last answer on 7/4/2020 2:29:23 AM. by S L Gupta (Civil Engg). Forum started by Sathya
4656
What is the RCC column size for 20 feet distance for two floor house.These 20 fe
Last answer on 2/23/2014 8:38:52 PM. by Navneet Jharia. Forum started by somvir
2962
Need suggestions
2244
4942
COLUMN AND STEEL DESIGN
4942
4656
1967
cost of construction for large span of 60'
Last answer on 10/30/2014 12:27:22 PM. by Amit Hasija. Forum started by amit jain
2480
3305
3318
4449
4020
2246
2724
4233
5204
2394
2319
2023
2463
2141
3214
2073
12540
2187
2029
2748
Right size cupola
What is binding wire
