Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Column structure...
Column structure...
Mon Mar 07, 2016Total posts : 4
R SURYAPRAKASHA
R SURYAPRAKASHA
Topic: Column structure...
I am constructing 30*40 house. There are 12 columns designed.
Each 9'*12' sie. Ground floor 6 Nos of 16 mm rods. 1st and 2nd 6 rods - 12mm each.
Total GF + FF + SF.
I am using red clay bricks with external 9 in and internal 4 in walls.
Can you please suggest on the structural design and how I can plan for watrertank? Can I raise another 5 feet for watertank and place in southwest corner?
Or directly on 2nd floor slab should be done, with small tank on an iron stand for slar water heater.
I have attached design details. Please advice on the overall structure planing and also on the water tank.
Thanks & Regards,
Surya.
Attachments: REINFORCMENET.zip on Mon Mar 07, 2016,&n
Mon Mar 07, 2016Post  #1
     You should follow the design drawing and if any doubts consult the architect or design engineer.
Mon Mar 07, 2016Post  #2
Please follow as suggested by the engineer.
Tue Mar 08, 2016Post  #3
R SURYAPRAKASHA
R SURYAPRAKASHA
Thank You Gupta Sir and Prakash.
Infact my engineer says the plan is strong enough and need not worry... :-)
As I am getting construction on my own just getting too many doubts.
And I need an expert advice from you also on the same.
Currently all 3 floors moulds done. GF and FF BRICK work done. Second Floor brick work going on.
Please find attached my floor plan and reinforcement plans.
Please advice.
Thanks & Regards,
Surya.
Attachments: REINFORCMENET.zip Tue Mar 08, 2016,
FloorPlans.zip Tue Mar 08, 2016,&n
Tue May 03, 2016Post  #4
Go for the same.
2616
COLUMN nd LOAD BEARING
1892
column STRUCTURE
Last answer on 11/9/2015 3:11:28 PM. by S L Gupta (Civil Engg). Forum started by DURJOU KUMAR MONDAL
2037
construction of second 7 third floor
Last answer on 1/2/2013 11:45:31 AM. by S L Gupta (Civil Engg). Forum started by kiran kumar 3k
1643
planning to construct a single storey house very close to the sea
Last answer on 6/16/2014 11:07:07 AM. by S L Gupta (Civil Engg). Forum started by nkumar
2749
1763
2131
Load bearing
Last answer on 1/17/2014 12:05:30 PM. by S L Gupta (Civil Engg). Forum started by Syed Shahed
2330
65238
3090
Last answer on 7/26/2009 8:35:08 PM. by Ganesh. Forum started by cosntruction novice
2142
About column and beam structure
Last answer on 1/4/2019 11:39:23 PM. by S L Gupta (Civil Engg). Forum started by Rana kachari
1895
Structural design
Last answer on 7/3/2020 10:29:46 PM. by S L Gupta (Civil Engg). Forum started by Akhil George
2296
RCC Framed Structure: Sequence of constructioin
Last answer on 12/27/2014 3:22:06 PM. by S L Gupta (Civil Engg). Forum started by Arvind Bhaskar
2115
Structure proof checking
2210
3017
6440
Column placement for house
4939
COLUMN AND STEEL DESIGN
4939
5811
3792
9884
2670
4627
4143
2865
5006
3655
1864
2800
2610
2372
2462
2638
1807
3608
6254
Earthquake
Termite Control
Through
Various
