Home -> Forums -> Construction -> Start Construction -> Columns and beams
Columns and beams
Thu Mar 26, 2015Total posts : 3
Biju
Biju
Topic: Columns and beams
Hello,
I am planning to build a single floor sloping roof Kerala style house around 1500 sq ft (3 bed 2 bath). I will be using 8" interlocking bricks instead of regular bricks. Is it necessary that columns and beams are a must or can they be avoided and the walls will bear the load?
Biju
Sat Mar 28, 2015Post  #1
The columns can be avoided, you may need few beams.
You wont be able to change much in the inner layout in future if constructing the floors above the ground floor.
Sat Mar 28, 2015Post  #2
Biju
Biju
Thank you very much for the prompt reply. This clarifies my doubt.
-Biju
Thu Apr 02, 2015Post  #3
Dear Biju
        In case of load bearing walls we can avoid columns.
In single story there is no need of columns.
2702
2720
1367
10048
3304
2037
2708
2304
2035
13774
overlap length to steel
2783
4212
Selection of cement ..
2559
1312
4800
tie beam obsolete
2332
beam load
Last answer on 9/16/2014 11:08:18 PM. by JAI PRAKASH. Forum started by rishabh
2937
concrete beam
Last answer on 11/22/2020 5:20:59 AM. by S L Gupta (Civil Engg). Forum started by daniel
3312
2236
2312
2061
Centering
Dining
Dining Room Ceiling
Through
