Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Columns marking
Sat Mar 26, 2016Total posts : 4
Anamika
Anamika
Topic: Columns marking
How are you all?
Please help me with this plan. Plan is attached here and same plan will go to first floor( G+F)
1.    1.    Kindly mark the minimum number of columns that I may need.
2.      2.  Right side of the plot there is 2 storey building so I do want to go for 4.5 inch wall thickness to save some space. Kindly mark other places where I can replace 9 inch thick wall with 4.5 inch thick wall
3.       3. Any other suggestions related to plan like changing in rooms or cancellation of stores etc
Your any help will be highly appreciated.
Thank you
Anamika
Sat Mar 26, 2016Post  #1
Anamika
Anamika
Plan is attached here. I'm sorry for missing in the above mail.
Attachments: GF.jpg Sat Mar 26, 2016,&n
Sun Mar 27, 2016Post  #2
Post subject: Columns Marked
Hello,, Anamika, Column positions are marked according to plan, There may be problem of cross ventilation in this plan,so kindly provide sufficient ventilation over the doors of both bed rooms. please see the plan attached.   Regards
Attachments: plangf.jpg Sun Mar 27, 2016,&n
Tue Mar 29, 2016Post  #3
Anamika
Anamika
Than you very much Mr. Jharia
But columns are too much. It will increase my house cost enormously
Tue Mar 29, 2016Post  #4
Dear Anamika
                  For proper design, drawing and MS Steel bars it is better to take help from structural engineer.
The depth of foundation is taken from the bearing capacity of soil/ land. In general the foundation depth should be up to hard strata of soil and minimum 4 feet.The size , number of column and other component can be calculated after the structural design. Because in  the design the thickness of foundation, size of column and MS Steel is calculated according to load coming or bear by the foundation irrespective of bearing capacity of soil and taking safety factor and safety from earth quack etc.
In my opinion you should act according to technically as your project is big and take no risk for a small amount of design. If we have proper design than we save the cost by tentative method and with safety in mind.
http://www.gharexpert.com/tips/articles/Construction/1730/Cement-Concrete-1730-Mild-Steel-Bars-in-Cement-Concrete_0
Delete
1847
plz suggest best n cheap isi marked switches?
Last answer on 1/8/2015 11:55:53 PM. by JAI PRAKASH. Forum started by ashok
3303
2131
poster for walls
Last answer on 1/2/2021 5:27:27 AM. by S L Gupta (Civil Engg). Forum started by SACHIN
1775
water pond or waterfall
Last answer on 2/8/2016 11:17:04 AM. by S L Gupta (Civil Engg). Forum started by SACHIN
3800
Orientation of Building
Last answer on 8/6/2010 2:09:05 PM. by narayan. Forum started by pooja
2068
beam and column
3793
15780
9000
4939
COLUMN AND STEEL DESIGN
4939
6439
Column placement for house
3017
3508
2567
2583
Re. eccentric footing.
Last answer on 12/6/2013 12:11:41 PM. by S L Gupta (Civil Engg). Forum started by vignesh_mp
8965
Last answer on 9/11/2020 2:17:26 AM. by hemant. Forum started by hemant
2550
Advise on accommodating a staircase in existing structural plan
Last answer on 5/30/2021 11:00:09 PM. Forum started by Naveen Reddy
2068
structure
Last answer on 4/21/2014 3:03:37 PM. by S L Gupta (Civil Engg). Forum started by HAMEED
5810
3792
9883
2670
4626
2865
5006
3655
1864
2799
2609
2372
2462
2637
1807
3607
6253
Electrical
