Fri Sep 26, 2014 | Total posts : 1 |
| Topic: Company and Cost of Solar panels for 3 storey building
Hello Sir/Madam
What are the points to check while purchasing Solar panels which brands do you recommend.
Thanks |
Mon Sep 29, 2014 | Post #1 | S L Gupta (Civil Engg)
Length of manufacturer’s warranty
Take note of what guarantees the manufacturer offers. If the
manufacturer is reputable and the warranty period on the panels is
substantial (at least 25 years) you would naturally expect your solar
system to last long for a long time, long enough to pay for itself and
make you a profit. However, for a warranty to be honoured, the
manufacturer needs to be still operating; so be cautious of brands
without a track record in Australia.
Have realistic price expectations
If you are paying substantially less than many other similar size
systems quoted, you may find poor quality equipment and/or poor
installation work. Quality equipment and installation isn’t cheap and,
like all other purchases, you often get what you pay for. Compare
components and warranty periods and check into the company providing the
installation. While large, well established companies can pass on
substantial savings due to increased buying power, other companies often
reduce costs by cutting important corners.
Solar panel certifications
This applies to all solar panel purchases, but especially to the purchases that could attract a government rebate.
The certification on solar panels indicates the type of testing that
has been done on them. For instance, TUV IEC 61215 confirms that the
solar panels have been tested by an independent laboratory and have met
their advertised specifications. Other certification types are
often self-assessed, therefore rely on the company being honest in what
it claims.
Decide on the type of panels
It used to be the case that if you had limited roof space you
would need highly efficient (and very expensive) mono-crystalline solar
panels. This is rapidly changing with advances in polycrystalline panel
technology and some thin film technologies. Still, even if you have
ample roof space you may still want to consider panel sizes vs. output
as filling up your roof with inefficient panels will affect your ability
to add more panels at a later date, and does not maximise the power
output of the space.
It’s also important to bear in mind that regardless of claim, no
solar panel technology will produce a significant amount of power in
full shade. Learn more about monocrystalline vs. thin film panels.
Solar panel mounting
Make sure that the roof, ground mounting or tracking system is
engineer certified for the area you are in. For example, if you live in a
cyclone prone area make sure the mounting system and mounting brackets
are also cyclone rated. Quality systems are wind certified; after all
you do not want your system to take off during a wild storm . The
mounting system is a very vital component and some suppliers skimp on
this item. Make sure you ask about wind certification, warranty
arrangements and get copies of relevant documents.
Solar inverter efficiency
Questions (39) | |
2007 views | 1 answers | Last answer on 11/10/2016 5:24:45 PM. by S L Gupta (Civil Engg). Forum started by Sagar | 2796 views | 1 answers | Last answer on 9/17/2021 1:06:03 AM. by Gunjan Utraja. Forum started by Jagajothi | 1652 views | 1 answers | Last answer on 3/29/2016 11:40:14 AM. by S L Gupta (Civil Engg). Forum started by riaz |
| 804 views | 0 answers | Last answer on 10/7/2020 11:58:13 PM. Forum started by S NAGARAJAN | 2697 views | 2 answers | Last answer on 6/7/2015 1:35:53 AM. by JAI PRAKASH. Forum started by sanjay | 2240 views | 0 answers | Last answer on 2/19/2014 9:25:54 PM. Forum started by ani | 1698 views | 1 answers | Last answer on 5/19/2016 12:31:25 PM. by S L Gupta (Civil Engg). Forum started by Rajendran | 2851 views | 5 answers | Last answer on 9/19/2012 6:08:49 PM. by tjackson. Forum started by Sujatha Kumar | 2635 views | 1 answers | Last answer on 7/3/2020 11:21:56 PM. by Gunjan Utraja. Forum started by Abraham | 2049 views | 0 answers | Last answer on 12/9/2021 3:54:54 AM. Forum started by deepak | 1584 views | 2 answers | Last answer on 7/13/2021 3:34:24 AM. by HardissonHard. Forum started by Rahul Bhandari | 3795 views | 1 answers | Last answer on 12/2/2014 12:34:34 PM. by S L Gupta (Civil Engg). Forum started by hemant | 3369 views | 4 answers | Last answer on 5/5/2021 12:20:43 PM. by Jordan80Evans. Forum started by kavita bhardwaj | 2165 views | 1 answers | Last answer on 10/19/2012 12:02:07 PM. by S L Gupta (Civil Engg). Forum started by ashish | 2255 views | 1 answers | Last answer on 7/4/2020 2:26:04 AM. by S L Gupta (Civil Engg). Forum started by Dhiraj Jain | 4651 views | 1 answers | Last answer on 11/10/2014 2:26:39 PM. by S L Gupta (Civil Engg). Forum started by hemant | 2253 views | 3 answers | Last answer on 7/4/2020 4:25:07 AM. by S L Gupta (Civil Engg). Forum started by Sunil T Deshmukh | 1727 views | 1 answers | Last answer on 10/8/2013 3:46:26 PM. by S L Gupta (Civil Engg). Forum started by sudheer | 2550 views | 1 answers | Last answer on 11/30/2021 11:44:17 PM. by S L Gupta (Civil Engg). Forum started by c k Ramaprasad | 12 views | 0 answers | Last answer on 12/21/2024 12:29:49 AM. Forum started by rupeshji | 9 views | 0 answers | Last answer on 12/21/2024 12:29:40 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:32 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:29:24 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:29:18 AM. Forum started by rupeshji | 10 views | 0 answers | Last answer on 12/21/2024 12:29:12 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:05 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:58 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:51 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:44 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:28:38 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:31 AM. Forum started by rupeshji | 8 views | 0 answers | Last answer on 12/21/2024 12:28:24 AM. Forum started by rupeshji | 15 views | 0 answers | Last answer on 12/21/2024 12:28:18 AM. Forum started by rupeshji | 17 views | 0 answers | Last answer on 12/21/2024 12:28:10 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:03 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:56 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:27:22 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:16 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:27:08 AM. Forum started by rupeshji |
Articles that might interest you! | | Solar Lighting Solar lighting conserves energy and lowers the cost of energy consumption. It is renewable and infinite source of ener.. | | Panel Doors- Advantages and Disadvantages Panel doors are quite popular in homes for various reasons. Panel doors are hard or provide more security and privacy .. | | Outdoor Lighting Outdoor lighting is essential to light up paths and walkways, outdoors, driveways, pools or other areas and improves s.. | | Orientation of Building To get maximum ventilation and natural light in your house, make sure the building is properly oriented. Orientation o.. | | Pool Heaters You spend a lot of money to construct a swimming pool and on its other equipments. But if your pool is frequently too .. | | What are various types of panel doors? Single panel, Double Panel, Three Panel, Six Panel doors........ | | Window Treatments: Window Blinds for Windows Know about the different styles of window blinds and add style with window treatments such as blinds, shades, curtains.. | | Garage door parts Understanding garage door parts can help you in choosing the style of garage door, maintaining, and increasing the life. | | Building New Home V/S Buying Builder Flat Buying a builder’s flat may be costlier for you rather than building a new home. But if you plan to make your own, you.. | | Cupola Proportions Tips for cupola proportions | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
