Home -> Forums -> Construction -> Basement -> Comparison between Basement and Additional Upper Floor
Mon Sep 20, 2010Total posts : 0
A Prasad
A Prasad
Topic: Comparison between Basement and Additional Upper Floor
What is the difference in basement and a term Semibasement used by Lucknow Development Authority
The comment above talks about the article   "Comparison between Basement and Additional Upper Floor "
2706
extend horizontally side wall for upper floor
Last answer on 10/27/2014 12:04:09 PM. by S L Gupta (Civil Engg). Forum started by navneet
2110
construction of hostle
Last answer on 6/21/2011 5:39:10 PM. by S L Gupta (Civil Engg). Forum started by eshwar
3941
3432
2257
may i know the lower portion and upper portio of the wall color
Last answer on 3/14/2010 7:25:28 AM. by Ajit Tareeka. Forum started by MARIBEL
2466
Retaining wall - Usage of Cement Plasticisers
Last answer on 7/23/2012 11:16:03 AM. by S L Gupta (Civil Engg). Forum started by George Kattapuram
2583
what is the wall thickness for a 9000 sqft building
Last answer on 4/3/2021 12:46:58 AM. by S L Gupta (Civil Engg). Forum started by shankar
1661
Can two foundation beds with basements be joined and maintain the structual stre
Last answer on 10/25/2014 8:54:11 PM. by JAI PRAKASH. Forum started by Gireesh
2706
Help required for construction of basement+ stilt+ 3 floors on 205 sqyd plot in huda gurgaon sector
Last answer on 3/16/2017 10:24:00 PM. Forum started by Mukesh
2048
estimated cost of additional room construction on 1st floor terrace
Last answer on 1/25/2014 11:49:44 AM. by S L Gupta (Civil Engg). Forum started by sujal
Structure strength to build additional floor(G+4)
Last answer on 12/14/2014 10:12:17 PM. Forum started by saravanan
2016
i want to know about plastering with marble paste and comparison with pop about
Last answer on 8/3/2010 12:02:34 AM. Forum started by sheth sandesh
2955
2482
Why you should buy uPVC Windows by WindowMagic at GharExpert.com
Last answer on 7/12/2011 10:22:48 PM. by Gunjan Utraja. Forum started by mona
13317
Marble Floor Comparison Required (Wonder Vs Katni Vs Dungri)
Last answer on 5/20/2014 12:04:53 AM. by Sunny Bansal. Forum started by Sunny Bansal
2865
Bricks
3992
2063
Sir, I am to build a basement leaving 2 meters each from both of side buildings.
Last answer on 9/15/2012 6:49:42 AM. by piyush. Forum started by Satish bajaj
9060
makan map
2774
17222
1993
2155
design of column
2281
2251
Underground water tank
2657
2764
foundation
2033
Full Plan Needed
3195
labour cost
3163
APP membrane
2796
1969
ffff
1871
4209
Selection of cement ..
3465
2016
Regarding construction
3154
Basement Water proffing
2014
Acid staining
Comparison
Basement Design Ideas
Vastu Guidelines for Basement
Basement Ceiling
Basement Flooring
Basement Interior Design
Garage doors style comparison
Comparing garage door styles and using this knowledge before buying a garage door will definitely save your money and ..
