Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Comparison between RCC Column and Reinforced Brick Masonry Column in a single story building
Mon Mar 04, 2013Total posts : 1
nasad
nasad
Topic: Comparison between RCC Column and Reinforced Brick Masonry Column in a single story building
Could you please tell me the difference between a RCC column and a Reinforced Brick Masonry column lined with Ferro Cement (chicken mesh & cement), of similar height, with respect to strength, cost and longevity.
Thanks and Regards
Tue Mar 05, 2013Post  #1
Dear Nasad
           RCC columns are constructed with MS steel bars and cement concrete with the help of shuttering made all round at the time of filling the column with cement concrete. Where as Reinforced brick masanary columns are where on outer side brick masonary sides are made than MS bars are laid in between the hollow space and this space is filled with cement concrete and this case shuttering is not required.There is not more differance in cost. Construct RCC column fior long term survival.
1864
2799
2609
2372
2462
2638
1807
3607
6254
3004
i wana construct a 18X14 feet hall single story .Is 9x9 column at corner os suff
Last answer on 9/19/2013 2:12:08 PM. by manishkumar. Forum started by manishkumar
4387
2718
3012
3941
4013
this is execelant front view,looking varities of front elevation for single sto
Last answer on 12/27/2020 8:48:44 PM. Forum started by Thakur Pattanaik
2158
Brick workmanship supervision
Last answer on 5/27/2013 11:28:55 AM. by S L Gupta (Civil Engg). Forum started by arctushar
2201
Brick Masonry Columns
Last answer on 1/14/2014 12:50:59 PM. by Ahmed. Forum started by Ahmed
1878
column
4939
COLUMN AND STEEL DESIGN
4939
2068
beam and column
3793
4799
tie beam obsolete
2832
how to make footing and column for g 2 building on water well
Last answer on 4/1/2013 7:09:40 AM. by Arun. Forum started by Arun
3432
2567
10047
5811
3792
2670
4627
4143
2865
5006
3655
Brick Arches
Centering
