Home -> Forums -> Construction -> Ground work -> Compound wall construction
Mon Nov 03, 2014Total posts : 6
Mahesh
Mahesh
Topic: Compound wall construction
Hi ,
I need to build compound wall for area of 12ft high and 40ft length 9 inches width with foundation . My contractor suggested this wall should be built with concert since this should prevent land side with 12 mm and 10 mm rod. He has coated  Rs.150000 for complete construction including labor charges. I need advice from experts suggest me if this right quote and right type construction to prevent land side.
Mon Nov 03, 2014Post  #1
Dear Mahesh
           This can be under stand and calculated if plan and detail is available. I do not follow why land slide, this wall is in plain area are hill. What is meant by concert.
Mon Nov 03, 2014Post  #2
Mahesh
Mahesh
Dear Gupta,
We building a Retaining Walls.There is a change of ground level between the land on either side of the wall in order to support the weight of the land retained on the higher side of the wall. The requirement for this extra strength of wall. Difference between higher and lower end of ground is 12 ft height.
I mean to say Concrete wall with pillars to support these wall.
Please suggest I can give more information
Mon Nov 03, 2014Post  #3
You should make RCC wall, not brick wall.
Tue Nov 04, 2014Post  #4
Ashok
Ashok
Post subject: compound wall
Dear sir,
Better go for RCC Retaining wall designed by a structural Engineer.
In my project work; we built a retaining wall in the cellar floor of area
200'0" X 400'0". In that design there is a concealed column for every 12'0" length of wall. And important thing is; do not forget to provide 50mm or 75mm openings in the wall at 1'0" apart, which will be useful for drain off water on the other side of wall.
My suggestion is, Even it is not a low budget, Better go for RCC Retaining wall given by a structural Engineer.
All the Best.
Tue Nov 04, 2014Post  #5
Mahesh
Mahesh
Thank you
Wed Nov 05, 2014Post  #6
please go through RCC DESIGN/ Get it from any RCC DESIGNER  and dont go
by design told by contractor
1815
3863
Compound Wall Construction
2836
4712
Compound Wall construction
Last answer on 4/23/2013 11:37:38 AM. by S L Gupta (Civil Engg). Forum started by Raj
5656
Last answer on 12/17/2020 5:53:41 AM. by shamsmehra90. Forum started by Nirmala Rangarajan
4546
Construction of Compound wall
Last answer on 8/4/2011 1:22:22 PM. by S L Gupta (Civil Engg). Forum started by Sambasiva Rao Ravuri
5555
1502
1703
858
5864
Estimation
3119
concrete brick or clay brick
6254
2399
3645
Compound Wall
13651
2069
Last answer on 9/16/2014 11:09:41 PM. by bijumohang. Forum started by bijumohang
1835
Hi ,I need to build compound wall for area of 12ft high and 40ft length 9 inches
Last answer on 11/3/2014 11:39:50 AM. by S L Gupta (Civil Engg). Forum started by Mahesh
3264
compound wall
2998
8161
software
3900
2730
1833
lanterns
3134
false ceiling
2245
about construction
1787
4155
Cement Coba
3077
Water Harvesting System
1677
1758
water tank
2059
1761
1634
Pool construction cost
1996
2738
Regarding roof beam
Fire Stair case
2646
2374
super structure
Canvas
Canvas Wall Art
