Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Compound wall details
Fri Sep 13, 2013Total posts : 5
Abhi
Abhi
Topic: Compound wall details
i plan to construt a compund wall lenth - 130 ft , Height - 6 ft and width 4.5" .
 compound wall with pillar for every 10 Ft and plinth beam with birck .
kindly tell me how much appr. cost  for both Material and Labour
rajendrakumar
Sat Sep 14, 2013Post  #1
Dear Abhi
     Cost of compound wall with foundation approximately Rs 50000-00
Sat Sep 14, 2013Post  #2
Abhi
Abhi
Dear sir,
Thanks for the information. Is the amount 50,000 including the Material and the Manpower compound wall with Plinth beam and Pillar with above mentioned measurement.
Rajendra kumar
Tue Sep 17, 2013Post  #3
Dear Abhi
    The cost is include material and labor both.
Tue Oct 01, 2013Post  #4
raj
raj
Dear sir,
I enclosed my house size,  1100 sq.ft with ground floor and same in First floor. ( Hall -16*16 , M.B. – 16*11 , Bed room – 11*12 and Kitchen 11*16 size)
1.Column post - 9” *12”  ( 12mm – 4 rods , 10mm – 2 rods)
2.Plinth beam  - 9”*12” ( 12mm – 6 rod)
3.for Roof slab – 12mm & 10mm rods
Kindly suggest the above steel useage  is enough for the my requirement
Thu Oct 03, 2013Post  #5
Dear Raj
          It is better to take design from structural engineer according to plan of the house.
However as per your question,
Use 16mm & 12 mm dia MS steel bars in columns with 8 mm dia rings at least at 6'' center to center.Rest seems O k.
5558
1823
1508
3003
details about wall claddings, tiles & all including its rate
Last answer on 10/8/2020 12:45:36 AM. by S L Gupta (Civil Engg). Forum started by laxmi
6081
i need details for wall panelling.
Last answer on 2/4/2013 11:53:42 AM. by Sonal. Forum started by Prabha
5879
Estimation
3126
concrete brick or clay brick
3649
Compound Wall
3865
Compound Wall Construction
2840
13659
6265
2403
1710
866
2076
Last answer on 9/16/2014 11:09:41 PM. by bijumohang. Forum started by bijumohang
3269
compound wall
1626
I have small land 6 perch.... so i have get drawn plan for 3 storied building. t
Last answer on 2/27/2015 4:02:19 AM. by JAI PRAKASH. Forum started by Sajeewa Lakmal
3572
Kitchen Pictures
Last answer on 8/28/2020 2:40:10 AM. by Swati Ray. Forum started by SUTANU RANA
5822
3802
9896
2675
4631
4147
2873
5224
5038
3667
4074
1869
2803
2614
2474
2642
1812
3617
6265
Canvas
Canvas Wall Art
Wall
Wall Decor
Paint
Wall
Wall Accents for Your Rooms
Beyond
Wall
Wall painting design
