Home -> Forums -> Construction -> Start Construction -> Conceeled beams
Conceeled beams
Thu Jun 18, 2015Total posts : 4
manjula
manjula
Topic: Conceeled beams
Hi sir,
We have different floor plans of ground floor & first floor, in first floor partition  walls are coming in between living & bedrooms of ground floor, so how can we provide beams in that case, can we go for conceeled beam?? or is there any other solution.
Waiting for the reply.
Thu Jun 18, 2015Post  #1
You can use conceeled beams or simple beams above the ground floor lantel below the partition walls.
Fri Jun 19, 2015Post  #2
LisaWolfe
LisaWolfe
Good one..!!!
Tue Jun 23, 2015Post  #3
Better if you consult with an architect or engineer at your local place.
This is a delicate matter.
Even a small mistake can be very costly in future.
Fri Jul 03, 2015Post  #4
True.
4669
Regarding Beam
2341
beam load
Last answer on 9/16/2014 11:08:18 PM. by JAI PRAKASH. Forum started by rishabh
3842
Roof Beam
4770
Last answer on 8/27/2012 4:35:27 PM. by Amit Hasija. Forum started by prakash
12274
3304
1982
2065
4677
RCC beam over plinth beam
Last answer on 7/3/2020 10:34:03 PM. by S L Gupta (Civil Engg). Forum started by rajeev
2526
3580
3159
Steel in Lintel
Last answer on 7/4/2020 3:06:52 AM. by JAI PRAKASH. Forum started by krishna pratap
1373
1950
Beam depth and wide depond upon
Last answer on 5/12/2015 2:42:50 AM. by JAI PRAKASH. Forum started by anil kumar Tiwari
3726
1787
What is aggregate
Last answer on 4/3/2014 11:18:54 AM. by S L Gupta (Civil Engg). Forum started by raza abbas
2726
2709
4031
labor rate for RCC work
2482
3307
3320
4450
4024
2247
2725
4235
5208
2396
2321
2025
2463
2142
3215
2073
12544
2189
2029
2750
Centering
Dining
Dining Room Ceiling
Through
