Home -> Forums -> Construction -> Interior Lifestyle -> Concrete Decor
Concrete Decor
Wed Sep 09, 2009Total posts : 4
manoj
manoj
Topic: Concrete Decor
I am very impressed with the article and the photos! my area of concern is the maintenance and how to protect from childern as concrete is very vulnerable and tend to break at the edges!
The comment above talks about the article   "Concrete Decor"
Wed Sep 09, 2009Post  #1
Priti Arora
Priti Arora
Post subject: Concrete staining
Concrete staining is solution for your problem; it will give the finished look to concrete and do not cause breakage of edges. Stained concrete is also easy to maintain.
Mon Feb 28, 2011Post  #2
pradeep
pradeep
Post subject: Concrete Decor
glass partition site does not open
Thu Mar 08, 2012Post  #3
ganesh
ganesh
need to know about concrete seatings
Sun Mar 11, 2012Post  #4
LULU
LULU
how to prepare these concrete slabs at home & colours
Interior Lifestyle-Construction Questions (23)
2234
HIDDEN WINDOW DECOR IN LIVING AREA
Last answer on 7/23/2018 11:37:55 PM. by S L Gupta (Civil Engg). Forum started by Nimit Panwar
2804
i need an information regarding the minimum cost of a wall decor with painting..
Last answer on 8/4/2018 2:36:29 AM. by S L Gupta (Civil Engg). Forum started by anoo
2952
Wall Decor
Last answer on 7/3/2020 10:15:08 PM. by neerajlalwani. Forum started by Laveena
1570
I would like to know where I can get the wall decor and how much it costs.
Last answer on 9/9/2011 10:50:08 PM. Forum started by Prakashrao
1790
i definetally love this exclusive designs,my quetion is do you offer training to
Last answer on 4/14/2021 1:57:37 AM. by S L Gupta (Civil Engg). Forum started by coaste
1767
1460
3470
Cost of concrete walls
3432
3278
2025
parts of concrete and size.
Last answer on 3/15/2011 6:16:45 PM. by S L Gupta (Civil Engg). Forum started by kanwer sajjad
2242
sand alternate for concrete
3770
concrete mix design software
3767
2276
2414
roof concrete
2413
1619
2106
1969
Last answer on 9/23/2021 1:44:52 AM. by seema tyagi. Forum started by SINDHU VASU
3257
Last answer on 12/31/2020 2:40:33 AM. by jk. Forum started by M K
2631
Interior Decorating Ideas
Last answer on 4/17/2011 5:06:47 PM. by Nikita. Forum started by pattipatisrinivasulu
1941
Staircase railings
Last answer on 5/18/2010 8:04:17 PM. by Vinutha. Forum started by Manju
Concrete Decor
Concrete Mix Ratio
Bedroom Decorating Ideas
Elegant bedroom décor may melt your all worries and tensions. Some simple but dazzling bedroom decoration or makeover ..
Ready
Ready Mix Concrete
Garden
Garden Decoration
A beautiful garden is a dream of every person that garden can be made more attractive with the addition of various dec..
Wall
Wall Decor
