Cement Concrete
Concrete Hollow Block Masonry
Sun Jun 29, 2014
s p kataria
Topic: Concrete Hollow Block Masonry
Is there any detail about Concrete Hollow Block Masonry, other than IS Code............
Wed Jul 02, 2014
Please check the link below for details:
http://en.wikipedia.org/wiki/Concrete_masonry_unit
3432
amit yadav
amit yadav
2627
Precasted Concrete Blocks
Last answer on 12/31/2020 2:22:20 AM. Forum started by
Girish
2027
Last answer on 1/19/2022 3:12:55 AM. by
viju
3841
Last answer on 6/16/2015 4:28:50 AM. by
aladin
2595
Last answer on 9/7/2012 4:18:47 PM. by
narsi vekeriya
4941
HOLLOW CORE CONCRETE SLABS
Last answer on 11/17/2009 12:39:06 PM. by
Girish
Girish
1989
Last answer on 6/1/2015 1:05:53 PM. by
Mohd
2184
Last answer on 1/29/2014 11:52:53 PM. by
gnyoganarasimhan
1732
2190
Size of the Roof Level Beam in RCC framed structure
Last answer on 1/30/2015 12:12:31 PM. by
Arvind Bhaskar
1863
Last answer on 1/5/2022 9:14:05 PM. by
sanjay agarwal
saradha
2256
Last answer on 5/3/2016 12:27:42 AM. by
navneet
3801
Masonry tool ADZE
Last answer on 12/31/2020 1:57:31 AM. by
Boovarahan S
Boovarahan S
Cost of Foundation
Last answer on 9/11/2012 1:51:22 PM. Forum started by
RENJI
1878
column
Last answer on 3/5/2021 2:07:49 PM. by
karthick
2068
difference betwen block board and ply board
Last answer on 12/31/2020 2:51:40 AM. by
Chetna
manisha
1775
what is the size of blocks
Last answer on 3/20/2012 12:26:58 PM. by
Abdul Salam Reki
1879
Is a apartment block anti-vaastu if it has a pond on its south
Last answer on 3/5/2021 2:56:01 PM. by
siddhartha
3469
Cost of concrete walls
Ar. Manoj Ralen
Ankur Kothari
1792
STP
Last answer on 5/18/2021 1:47:12 PM. by
Nijesh Ramraj
3106
Last answer on 12/31/2020 1:53:26 AM. by
N.S.BISHT
Pujesh Mallick
3651
Last answer on 9/17/2020 9:19:38 AM. by
Razi
4349
rate comparison
Last answer on 7/4/2020 2:15:33 AM. by
aammiitt
aammiitt
3203
Concrete Mixture
Last answer on 7/4/2020 2:11:26 AM. by
Ar. Manoj Ralen
Navneet Shahrawat
3142
sloping roof
Last answer on 7/4/2020 2:00:34 AM. by
ekonagu
2090
Last answer on 7/4/2020 1:58:38 AM. by
abdul
15805
Last answer on 7/3/2020 11:48:29 PM. by
Mohan
6470
Last answer on 4/5/2018 12:39:19 AM. by
Sanzana Hosen
2379
leakage in new slab
Last answer on 7/15/2017 3:57:04 AM. by
rajeev
milind
1527
Guide me
Last answer on 3/22/2017 12:35:27 PM. by
Subash
5118
Last answer on 1/25/2017 5:30:02 PM. by
vinod singh
2535
Civil Eng Stair Design
Last answer on 2/1/2016 1:27:20 PM. by
swarooppratap
2535
swarooppratap
Related to Sunken Slab
Last answer on 10/25/2015 8:30:24 PM. by
SOUNAK SAMANTA
1857
Last answer on 8/22/2015 7:13:59 PM. by
bala
2414
roof concrete
Last answer on 5/22/2014 1:50:02 PM. by
sakthi
3199
Ready Mix Concrete
Last answer on 10/7/2013 11:24:46 AM. by
sck
Concrete Decor
Concrete Mix Ratio
Ready Mix Concrete
