Home -> Forums -> Construction -> Green Building -> Concrete Roof Insulation
Fri Jun 24, 2016Total posts : 1
Omar Chaudhry
Omar Chaudhry
Topic: Concrete Roof Insulation
Hello all.
I am looking at different options for concrete roof insulation.
My house is under construction, so any change / amendment can easily be made at this stage.
There are 2 open to sky terraces on first floor ( 300 sq feet each ) , with rooms below them on Ground Floor. So I need to insulate the floors of these terraces to stop summers heat from entering the rooms below. Please note that at finishing stage I would be installing marble or porcelain tiles in these terraces.
Further, the top most roof of first floor is about 4,000 sq feet. I would like to insulate this as well, to save the rooms on first floor from direct heat of summers. Upon finishing here I would lay 4" to 5" compacted mud, and then brick-tiles over this.
My query is for both of the above said insulations, should I be using XPS ( Extruded Polystrene sheet ) or  EPS ( Expanded Polystrene sheet ).  For 2" thickness, my understanding is that both give same level of heat insulation.  For water proofing I would be using bitumen + Polythene.  So for heat insulation which product is better , less costly, with longer life ?   Generally the EPS is cheaper than XPS, so is it worth to spend more for XPS ?
Please advise.
Thanks in advance
Sat Jun 25, 2016Post  #1
Dear Omar
Thermal insulation is a method to reduce the transfer of heat from outside to inside. To make house heat proof, thermal insulation is a good choice. An insulated home is more comfortable as the temperature remains consistent over weather changes. It makes the house comfortable and keeps the temperature of   house cool in summers and warm in winters. It is very useful to keep the temperature of the house independent from outside temperature.
General Principles of Thermal Insulation
• Thermal resistance of an insulating material depends on the type of material and the thickness.
• Provision of an air gap is very important and useful insulating agent.
• Orientation of the building has important role in thermal resistance.
• The building/house design is done in such a way so that entry of solar energy in summer should be minimum and in winter it should be maximum.
Choice of Insulating Materials
Choice of insulating material depends on following considerations.
• Cost of insulating material.
• Area to be covered for insulation.
• Standard of insulation to be required.
• Cost of energy consumed for heating and cooling.
• Reasonable fire proof
• Non absorbent of moisture
• Not liable to undergo deformation
• Resistant to attack of small insects
Insulating Material
1. Rock wool.
2. Slag slabs
3. Mineral wool slabs
4. Aluminum foils
5. Cement concrete block with lightweight aggregate.
6. Gypsum board
7. Asbestos cement board
8. Clip board
9. ACC cement board
10. Chip board
11. Foam glass
12. Gasket cork sheet, foam plastic etc.
How to apply insulating material
Apply CPRX compound of Shalimar Tar Products (STP) on ceiling of roof.  For fiberglass or glass wool insulation, you can fix 2" thick pieces. For Thermocol or rubber foam, you can fix 2'X2' pieces. These can also be fixed into wooden frames 2' X2' size. Finally, cover the treatment with 24 gauze perforated aluminum panel.
How Thermal Insulation is Beneficial
 Comfort: The temperature of the room remains cool in summer and warm in winter than that of outside atmosphere. Therefore, by providing thermal insulation one feels comfort both in summer and winter season.
 Fuel saving: Fuel is required to maintain desired temperature of the room. By providing thermal insulation, the transfer of heat/cold reduces between inside and outside of the room.. Hence, it saves fuel.
Condensation Resistant: Thermal insulation materials fixed on inside surface of the room walls prevent condensation on interior walls and ceiling. Condensation is deposition of moisture and takes place when warm air comes in contact of surface having temperature below dew point.
Thermal Insulation of Exposed Walls
The heat and cold radiate through exposed walls of the house. There are following methods of thermal insulation of exposed walls.
1. You may provide suitable thickness of wall.
2. You may provide Hallow wall or cavity wall.
3. You may fix Hardboards or ply board on wooden batten over the wall for creating air space.
4. You may fix Thermal insulating material sheet inside and outside exposed wall to reduce heat/cold transmission.
5. You may construct outer wall with thermal insulating material if you have frame structural building or non-load bearing walls.
Thermal Insulation of Exposed Doors and Windows
Outside doors and windows transmit heat/cold through the room from atmosphere. The methods providing thermal insulation are following.
1. The frames of doors and windows are of wood.
2. You should not use Iron or pressed steel frames as they transmit more heat and cold than that of wood.
3. You may fix Insulated glass in glazed doors and windows.
4. Double glass with air space provided on glazed door will reduce transmission of heat/cold from outside to inside.
5. You may provide sunshade projection on doors and windows to protect them from heat and rain.
6. You may use Curtains, ventilation blends etc. on exposed doors and windows.
Thermal Insulation of Exposed Roof
The roof of the one storey building or top roof of multi storey building is an exposed roof. Heat/cold transmits through exposed roof in the building. There are two types of treatment for thermal insulation of exposed roof by providing treatment at the bottom or top of roof slab.
a) Internal Treatment:
1. You can treat both types of slabs both types of slabs either flat roof or pitched roof.
2. You should provide Air gap for under exposed surface of roof by fixing false ceiling under the roof.
3. Ventilation abutting the roof also helps for passing the heat out of the room.
4. You should install false ceiling with thermal insulating materials.
5. You may paste suitable adhesive and sealers at inside surface of the exposed roof for fixing Light insulating materials. Some insulating materials are glass wool, fiber glass wool, mineral wool, thermocol, rubber foam etc.
b) External Treatment:
 Suitable shade may be provided on exposed top surface of the roof for reducing solar radiation.
2. Shining and heat reflecting coating may be applied on the top of exposed roof like paint.
3. These coatings can serve dual purpose of water proofing and heat reflection.
4. In case of flat roof you can create air space on top of roof by placing asbestos sheet on brick pillars.
5. The surface temperature of flat roof may be reduced by sprinkling water on roof at regular intervals during hot hours.
6. The surface of flat roof may be kept cool by storing water on roof.
7. ‘Mud Phuska’, which is a mixture of clay soil, wood shaving, and water, should be laid on exposed roof acts as thermal insulation.
8. The earth laid under tile terracing on top roof also serves the purpose of thermal insulation and helps in giving proper shape for drainage of rain water.
1.
Green Building-Construction Questions (38)
INSULATIONS
Last answer on 11/16/2009 6:59:34 PM. by Girish. Forum started by Girish
2414
roof concrete
2413
2106
3271
Roof Concrete Strength
2829
2027
1699
My House is 10 years old and my Existing Concrete roof in Hall area started to p
Last answer on 4/5/2018 12:46:08 AM. by S L Gupta (Civil Engg). Forum started by soundar
1066
2138
Roof insulation
Last answer on 9/20/2014 12:13:54 PM. by S L Gupta (Civil Engg). Forum started by sb
3142
sloping roof
11246
CURING ON ROOF CONCRETE
Last answer on 3/19/2014 10:26:34 AM. by Ahmed. Forum started by K Umapathi
2211
Roofing cost for 3000 sqft 2nd floor roof
Last answer on 6/17/2015 6:56:38 AM. by JAI PRAKASH. Forum started by sira
9195
2948
Lightweight Concrete Roofing
Last answer on 10/31/2012 12:32:07 PM. by S L Gupta (Civil Engg). Forum started by Ted Junior
1893
1585
RCC Roof before concrete floor
Last answer on 6/4/2013 10:29:06 AM. by S L Gupta (Civil Engg). Forum started by shilpa
1833
roof farming
Last answer on 2/25/2022 4:26:25 AM. by S L Gupta (Civil Engg). Forum started by raj
3267
Last answer on 1/24/2022 9:52:50 PM. by S L Gupta (Civil Engg). Forum started by Akash Sharma
3178
Architect to Build Green Modern Home in Bangalore
Last answer on 11/21/2021 1:07:48 PM. by fabions. Forum started by rahulsharma
2914
Help with a documentary about sustainability
Last answer on 10/5/2021 8:27:02 AM. by S L Gupta (Civil Engg). Forum started by Chibi Moku
3020
hpl panels for exterior
Last answer on 8/26/2021 8:40:25 AM. by HardissonHard. Forum started by kamal
2876
estimation
1798
Last answer on 7/4/2020 2:05:29 AM. Forum started by Alisson Chan
2142
Marriage Palace & School Auditorium
Last answer on 7/3/2020 11:27:36 PM. by S L Gupta (Civil Engg). Forum started by Marinedeejay
1767
House plan
Last answer on 7/3/2020 11:15:18 PM. by JAI PRAKASH. Forum started by udaykumar mugali
3492
Last answer on 7/3/2020 9:53:22 PM. by seema tyagi. Forum started by Modern Homes
1319
Is there any transparent sheets available for tress work on roof so as to cultivate on Terrance?
Last answer on 2/21/2017 12:33:33 PM. by S L Gupta (Civil Engg). Forum started by vinu
1733
Solar energy integrated houses
Last answer on 7/6/2015 12:24:02 AM. by JAI PRAKASH. Forum started by Kumar
4194
Low cost housing option
Last answer on 8/11/2014 9:23:57 PM. by JAI PRAKASH. Forum started by Dinesh Sharma
2088
Low cost roofing solution over a slanting slab for internal cooling
Last answer on 12/1/2013 8:03:10 PM. by Girish. Forum started by Girish
1827
Cost of construction - Less expensive?
Last answer on 10/16/2013 12:53:12 PM. by S L Gupta (Civil Engg). Forum started by Prasad
2657
cost of construction of type G + 2
Last answer on 8/26/2012 4:08:55 PM. Forum started by santhosh
2711
Chemtreat India
Last answer on 9/8/2011 3:05:20 PM. Forum started by Chemtreat India
2265
interiors
Last answer on 7/15/2011 4:05:38 PM. Forum started by keerthi
Thermal
Thermal Insulation of Home
No one likes to work in an uncomfortable environment where the temperature is either too hot or too cold. It is import..
Cooper
