| Advantages of Kota Stone Flooring Kota stone flooring is a subtle blend of grandeur and luxury giving the interior and exterior a gorgeous look....... |
| Appropriate Place for Kota Stone Flooring? Appropriate places for Kota stone flooring--Bed-room,Drawing cum dining room....... |
| Colors of Kota Stone Kota Stone is a natural stone found in attractive, beautiful and eye soothing natural shades of greenish blue and brow.. |
Which finishing material is recommended for Kota stone flooring? After the grinding with machine and polishing the floor, oxalic acid shall be dusted over the surface................... |
| Terrazzo flooring (Mosaic or Marble chip flooring) Terrazzo flooring is popular for residential as well as public buildings since it is not slippery when wet.
How to level concrete sub floor before installing wooden block flooring? The recommended method for leveling of concrete in wooden block flooring is described in the writeup. |
Refinishing Hardwood Floors When you feel that the finishing of the floor is out of fashion or you are getting bore of it, refinish your old hardwoo |
Checklists for flooring While going for any construction everyone needs some handy points on every stage of construction so as in while laying.. |
| Comparison between Basement and Additional Upper Floor Construction of basement and multi storey building is the need of the hour as there is less availability of land and r.. |
| Drawing Room Flooring Drawing room is a room where you welcome your guests; it should reflect your taste and personality. Flooring is major .. |
