Home -> Forums -> Construction -> Layout and House Plans -> Constructing a new house
Wed Jan 05, 2011Total posts : 6
Sundeep
Sundeep
Topic: Constructing a new house
Hi ,
I am starting the construction of a house in 260 sq yards of plot in hyderabad.
The dimensions of plot are as follows:
52E * 54W * 45N * 39.1S
As per the requirement of Municipality we need to leave 3ft on each of the sides which is coming to 600 sq feet
Is it possible to build a normal size 2BR house and also a couple of rooms as servant quarters at the back of the house and also accommodate parking space for 2 big cars ????
Please help me with your thoughts !!!!
Fri Jan 07, 2011Post  #1
kamalesh
kamalesh
Yes, you can.  It has to be a multistorey building with pillar construction.  Like appartments, ground floor as parking with a servant qtrs.
rgds,
Kamalesh
Sat Jan 08, 2011Post  #2
Sundeep
Sundeep
Post subject: hi
Thanks for your reply, but I want to build a 2BR house + servant quarters + leave space for parking in the G floor itself
I will be building another 2 floors on top.
Sun Jan 09, 2011Post  #3
vijay
vijay
Post subject: hi
hi my name is vijay , i m working in dubai  with one big architectural firm.
 it is possible 2 bed room house & parking area.
Mon Jan 10, 2011Post  #4
Ar. Suresh Kothari
 Ar. Suresh Kothari
Post subject: house design
After leaving 600 sft as the marginal area. The ramining area for construction is coming 1740.00sft.
Hence you can construct the house with two bed rooms and small parking space in the front, but you can have servant room of one room with small toilet only.
3' margin is very less for the sufficient ventilation. Here in Vadodara we have to leave 7' margin.
from
Ar. Suresh Kothari
Sat Apr 09, 2011Post  #5
Rahul
Rahul
Post subject: Design
My name is Rahul. I am planning to construct a house. It is east facing and measurment is  width 31ft. and length 51 feet. Request you to give me a design plan for
1.3 bedroom
2.1dinning and 1 drawing room
3.Kitchen
4.Puja
5.1 attached bath cum toilet
6.1 separate bath cum toilet
Carpet area can be used upto 1100 sq feet.
Thanks in advance.
Mon Apr 18, 2011Post  #6
Simon
Simon
Post subject: vijay
Hi, vijay, I can help for house furniture decoration
MSN: simon-qumer@hotmail.com
2637
2304
New Home
2431
2007
5946
new construction in 300 sq yards place ...planning
Last answer on 2/20/2011 12:22:40 PM. by Gunjan Utraja. Forum started by vihal madishetty
2950
1791
Want to construct a new house in limited budget, area 35*35 .
Last answer on 10/20/2015 2:24:22 AM. by JAI PRAKASH. Forum started by Kiran
2098
Last answer on 11/21/2015 12:12:42 PM. by SACHIN. Forum started by SACHIN
3492
14256
Demolition of Old house and constructing New house
Last answer on 1/21/2011 11:04:22 AM. by Archit Jain. Forum started by Kanchana
3308
Last answer on 5/1/2012 11:09:41 AM. by S L Gupta (Civil Engg). Forum started by pankaj sharma
3063
we want to demolish this old house and want to construct a new one. but the problem is there are neighbors whose walls are in touch with our wall so if we demolish and if their wall collapse then we will have to construct their wall also.. they are not ready to construct a new one. what is the solution..
Last answer on 5/20/2014 2:47:38 PM. by S L Gupta (Civil Engg). Forum started by vijay
1683
construct the new house
Last answer on 12/25/2013 1:57:17 PM. by S L Gupta (Civil Engg). Forum started by saravana
1530
What would be the estimate for constructing a new house in 117Square yards(22X4
Last answer on 11/13/2014 6:25:24 PM. by JAI PRAKASH. Forum started by mahesh
3550
CONSTRUCT A NEW HOUSE PLAN
Last answer on 4/24/2012 1:26:41 AM. by Gunjan Utraja. Forum started by sanjay
4036
2405
I want to see new houses exeterior image&living room
Last answer on 7/3/2020 10:57:28 PM. by S L Gupta (Civil Engg). Forum started by rakesh13
2385
i m start new house
Last answer on 5/17/2021 2:35:58 PM. by David80Dyson. Forum started by king jain
2315
so pls sugest eme start new house acc to vastu shastra
Last answer on 12/30/2010 9:09:03 PM. by S L Gupta (Civil Engg). Forum started by king jain
2676
2912
2176
2170
2770
4498
1875
2273
2245
2750
3451
2345
1951
2212
3584
2076
2782
1538
2109
Happy
Happy New Year 2009
Happy
Painting
Environmentally
