Mon Jun 27, 2011Total posts : 8
riaz
riaz
Topic: Construction of Brick Pillars
sir kindly let me know what should be the minium span distance between two colunms or for what size of a colunm can i have 25 feet gap between them. also i want to build first floor in my existing house but i will able to have colunms only in the sides will it work.
The comment above talks about the article   "Construction of Brick Pillars"
Tue Jun 28, 2011Post  #1
Dear Riaz
 The span or distance between the RCC columns depends according to site condition and size and MS Steel bars are according to loading condition, spanetc.It is not possible to tell about RCC columns without plan of the building. In my view you should consult structural engineer of your city for structural advice.
Tue Jun 28, 2011Post  #2
P. Panchal
P. Panchal
Post subject: column size
Mr. S. L. guptaji is right. plan is required to give any advice. it is a critical matter, and it can not be done without engineer's help.
Thu Oct 25, 2012Post  #3
Tanaji
Tanaji
Post subject: Construction of Brick Pillars
what will be the labour cost for beam construction and slab 4.5" constrution
Sun Dec 29, 2013Post  #4
pradip shinde
pradip shinde
Dear Sir, for single storey building for 1100 Sq-Ft construction, what should be the ratio of steel and cement concrete is to be used for Pillars,Columns and Slab (4.5")
Tue Jan 21, 2014Post  #5
ganeisa
ganeisa
Dear Vastu experts, My house plan has 17 pillars.Is it correct or it should be 18? The house foundation work is going on. Please let me know.Thank you very much
Wed Mar 12, 2014Post  #6
wasim
wasim
Hi i am planning to construct another floor at my house i want to know how much expenses will come for construction of RCC slab on 1300sft with 12 pillars in hyderabad
Fri Jun 06, 2014Post  #7
a.monteiro
a.monteiro
Hi Sir, I would like to know how much will be the cost to construct 15 coloumns and RCC terrace slab on my first floor house area of 1011.8sq ft which is located in Goa .The ground floor is already contrructed. 15 coloumns and a flat RCC terrace slab. Kindly advice
Fri Jul 25, 2014Post  #8
siva
siva
How to calculate the number of rods used in the pillar. In our house they have kept 6 vertical bars.. But is it not sufficient to use 4 bars?
6431
1802
2688
type of brick
1515
Guide me
2949
15352
2nd floor construction
9180
2018
Need to strengthen brick wall and brick pillar house
Last answer on 5/3/2016 12:24:38 AM. by JAI PRAKASH. Forum started by Sudipto Choudhury
3113
RCC pillar
Last answer on 7/3/2020 11:32:16 PM. by gpeter. Forum started by gpeter
2144
2510
construction const
2184
Last answer on 12/31/2020 8:58:35 PM. by S L Gupta (Civil Engg). Forum started by Joseph Santhosh
12412
First floor construction
2258
RCC roof on other than pillar
Last answer on 11/26/2015 3:34:20 PM. by S L Gupta (Civil Engg). Forum started by Binoy Rabha
1353
SirAfter construction of the basement slab, can the pillar work for the ground f
Last answer on 9/4/2017 12:35:46 AM. by S L Gupta (Civil Engg). Forum started by Joseph Santhosh
2682
Last answer on 2/20/2014 11:14:47 AM. by S L Gupta (Civil Engg). Forum started by HM12345
3595
3591
278
82
29
26
31
31
30
28
28
29
25
25
21
31
22
30
27
23
Brick Pillar
Brick Arches
Specification of Brick
