Home -> Forums -> Construction -> Start Construction -> Construction of Compound wall
Thu Aug 04, 2011Total posts : 3
Sambasiva Rao Ravuri
Topic: Construction of Compound wall
Hi All,
I'm planning to construct Compound wall construction for my house.
The length and depth of my site is 46.5 and 70 feet respectively.
I would like to construct compound wall strongly and at the same time am looking for cost effective.
Please suggest me how can i proceed for the same.
Regards, S Ravuri.
Thu Aug 04, 2011Post  #1
Dear S Ravuri
The design of compound wall is in direct relation to the height of compound wall.The height should be given so that design can be given.
Thu Aug 04, 2011Post  #2
Post subject: Construction of Compound wall
The Height of the foundation is 4.5 Feet from ground level. So, planning to construct compound wall, by doing excavation of 3 feet and on top of it, arround 8 to 9 feet wall construction.
Please suggest me what is the best procedure for cost effectively and strongly we can construct compound wall.
Note: Beam will be there after excavating 3 feet and another beam will be there at foundation level.Each 5 to 6 feet gap, one column will come. This is what the initial idea.
S Ravuri.
Fri Aug 05, 2011Post  #3
Dear S Ravuri
               There are two ways for constructing 8' high wall i.e To construct RCC columns @ 10' to 12 feet interval and second option is to construct 9'' wall with brick pillar 1.125x 1.125 @ 9to 10 feet interval , using cement and coarse sand ratio 1;4.
1815
5554
1502
1703
858
5864
Estimation
3118
concrete brick or clay brick
3645
Compound Wall
3862
Compound Wall Construction
13651
2836
4712
Compound Wall construction
Last answer on 4/23/2013 11:37:38 AM. by S L Gupta (Civil Engg). Forum started by Raj
2398
5655
Last answer on 12/17/2020 5:53:41 AM. by shamsmehra90. Forum started by Nirmala Rangarajan
2769
Last answer on 11/5/2014 9:02:10 PM. by SANJAY DUSANE. Forum started by Mahesh
6254
2069
Last answer on 9/16/2014 11:09:41 PM. by bijumohang. Forum started by bijumohang
1834
Hi ,I need to build compound wall for area of 12ft high and 40ft length 9 inches
Last answer on 11/3/2014 11:39:50 AM. by S L Gupta (Civil Engg). Forum started by Mahesh
3264
compound wall
3312
2236
2312
2061
Canvas
Canvas Wall Art
