Wed Jul 11, 2012Total posts : 97
Bimlendra Jha
Bimlendra Jha
Topic: Construction Cost for RCC Roof / Slabs
I am making a home at interior location, the area is 1400 Sq. Ft. how to calculate the slab/RCC roof cost approx, please advcie a calculator.
Bimlendra Jha
Go to page: 1 2 3 4 5 Next   >>
Wed Jul 11, 2012Post  #1
Dear Jha
         For calculating the cost of the slab, if your area of slab is without beam than the cost of Rcc slab excluding MS steel is Rs 80-00 per sq feet.and cost of steel bars is 72-00 per sft to the prevaling rates in july 2012.
Wed Jul 11, 2012Post  #2
Bimlendra Jha
Bimlendra Jha
Post subject: RCC Slab/ Roofing
Thanks for your immediate response, can you please tell me what is the ideal size of thickness of a slab
Bimal Kumar
Wed Jul 11, 2012Post  #3
Dear Jha
        The thickness of RCC slab depends on many factors i.e. Span of the slab, concrete mix use in the slab and steel use in the slab.
However the thickness of slab should be 4.5'' or 5''.
Wed Jul 11, 2012Post  #4
Bimlendra Jha
Bimlendra Jha
Post subject: Thanks
Respected Sir,
Thanks, i have got perfect answer for my confusion, i think this is a magical forum for all construction industries.
Bimlendra Jha
Fri Jul 20, 2012Post  #5
sam_m400
sam_m400
Sir
  Then if i need to RCC 1200 Sqft = 152 * 1200 = 182400 lakhs would be rate .is it inclusive of labour + material ?
sam
Sat Jul 21, 2012Post  #6
Dear Sam
     The cost is inclusive of labor, material and shuttering etc complete.
Sat Jul 21, 2012Post  #7
sam_m400
sam_m400
Sir
Thanks for your valuable inputs.
How much it cost inclusive of labour for pillar/beam/lintel/plinth/chejja per Sq:ft? This will help in calculating the approximate overall cost
Sam
Mon Jul 23, 2012Post  #8
Dear Sam
  The per sft rate is depend upon the thickness of beam , column etc.
Sat Sep 08, 2012Post  #9
kamathak2002
kamathak2002
Post subject: Labour Cost of Roof
Query on Labour Cost for Roof:-
I have hired a small contractor (labour contract on sq. ft/cu.ft) for centring works for my two storied house in mangalore.
The Contractor has now completed RCC for second floor Roof. The contractor’s quotation for second floor roof RCC  is Rs. 40.70 per sq. ft for 4 ½” thick , 10 ft height  .
The size of Roof is  41.50 ft x 38.20 ft(1585.30 sq.ft).
The Centring Contractor has made roofing by having flat surface from bottom of slab and sloping on top surface of slab for easy flow of rain water. The centre of roof has thickness of  6”and sloped either side on top surface to end at 4 ½”.
Do I have to pay extra labour cost to the centring contractor due to increase in thickness of roof slab since materials(cement, gravel , steel and sand) is supplied by me?
Kindly advise
Attachments: Roof Construction cost querry.docx Sat Sep 08, 2012,&n
Mon Sep 10, 2012Post  #10
For detailed reply please refer to link (of same query again asked by you at following link:)
Here is the link:
http://www.gharexpert.com/Forum/Labour-Cost-Roof-RCC-work/
Fri Sep 14, 2012Post  #11
atin
atin
Post subject: RCC ROOF COST
SIR,
Iam going to renovate my DDA flat.contractor quote me 820 rs/sqft (with material+labour,,for roof , walls , and columne). but i want to construct only RCC roof (with material and labour), then he quote me 750 rs/sqft.
please suggest me the actual value for the same.
Fri Oct 05, 2012Post  #12
Dear Atin
            The cost of laying of RCC slab with MS STEEL and material ,labor and shuttering should be Rs180 to 200-00 per sft. As you stated walls are already errected for old house.
Thu Oct 25, 2012Post  #13
Tanaji
Tanaji
Post subject: labour cost for beam and slab 5"
what will be labour cost for beam and slab 5"
Fri Oct 26, 2012Post  #14
The labor cost of casting RCC beam and slab including centering and shuttering when calculating in cubic feet i.e. length x breadth x height ( thickness)= rs 85/ per cubic feet including the hiring charges of shuttering material.
Fri Oct 26, 2012Post  #15
Tanaji
Tanaji
Thank you for your immediate reply.
Fri Oct 26, 2012Post  #16
Tanaji
Tanaji
Post subject: construction cost for stair
what will be construction cost of 10 ft high stair case excluding material cost
Mon Oct 29, 2012Post  #17
Dear Tanaji
       The cost can be calculated on the basis of design i,e. slope of stair, nos of steps etc. However if you are constructing RCC stair case than measure it in RCC rates as given above.
Tue Dec 11, 2012Post  #18
chetan anand
chetan anand
Post subject: Construction related issue
Can you please tell me procedure for conducting load test on a rcc ramp at site? Which code book should I refer?
Tue Jan 08, 2013Post  #19
maks73
maks73
What will be cost of 3 slabs of 1000 sqft  plus plinth 800 sqft in Pune.  Costruction will have 6 beam plus 2* 20 ft column  wach measuring 1ft * 1ft.
Wed Jan 09, 2013Post  #20
9907
4655
2341
3759
2983
2037
4954
3985
Roof leakage
4814
1879
3970
cost estimater
11850
cost of rbc and rcc slab
4846
1601
Last answer on 1/5/2022 8:30:54 PM. by S L Gupta (Civil Engg). Forum started by Pranav
3091
11118
2618
Last answer on 5/26/2016 10:55:05 AM. by S L Gupta (Civil Engg). Forum started by Madhu Ranjan
AuStRalia!!CaNaDa" 91- 8769373431VASHIKARAN sPeCiAlIsT
Last answer on 12/30/2024 1:08:23 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:17 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:11 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:05 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:58 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:52 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:46 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:40 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:34 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:27 AM. Forum started by rupeshji
Muslim-Shakti-Astro 91-8769373431Black Magic Specialist In Dubai,,qatar
Last answer on 12/30/2024 1:06:59 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:47 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:39 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:33 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:27 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:21 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:15 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:09 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:03 AM. Forum started by rupeshji
Boy / Girl 91-8769373431~iNtErCaSt LoVe MaRrIaGe;;LoVe BaCk SpEcIaLiSt
Last answer on 12/30/2024 1:05:50 AM. Forum started by rupeshji
Iron
Iron Sheet Roofing
