Construction Cost for RCC Roof (520 sq ft) in Howrah
Tue Dec 27, 2016Total posts : 5
Rahul
Rahul
Topic: Construction Cost for RCC Roof (520 sq ft) in Howrah
Can anyone tell me what will be the approx cost of constructing RCC roof in an area of 520 Sf ft in Howrah, West Bengal?. (including material, labour etc)
Wed Dec 28, 2016Post  #1
Dear Rahul,
        The cost of 520 sft area slab/ roof with cement concrete ratio 1;1.5;3 including material,labor,shuttering and MS steel is approximately Rs 80000-00.
Fri Dec 30, 2016Post  #2
Rahul
Rahul
Thank You very much. :)
Sat Dec 31, 2016Post  #3
Dear Rahul,
       During construction if we spent some time about design, specification and quality of construction than there is lot of improvement one can find in construction.
gharexpert.com website provide maximum engineering detail relating to construction if one have time and read these.
    Visit again for any problem relating to construction.
Thu Jan 26, 2017Post  #4
Rahul
Rahul
Thank You sir for your suggestions.
My contractor recommended me to use 8mm TATA TMT bar for main RCC slab and 12mm for beam. Its 1st floor roof contaction. What you say about this? give me some suggestion.
Fri Jan 27, 2017Post  #5
Dear Rahul,
        The size and spacing of MS Steel bar is calculated on the basis of design. In general design use at least 10 mm dia tor steel bars for main in RCC slab and in beam above 10 feet span of beam use 16 mm dia tor steel bars.
4647
13755
2613
Last answer on 5/26/2016 10:55:05 AM. by S L Gupta (Civil Engg). Forum started by Madhu Ranjan
2745
2665
sir i want to know that what would be the cost total consturction of 2200 sq.ft
Last answer on 2/15/2022 11:12:49 PM. by JAI PRAKASH. Forum started by shruti Adarsh
2033
23866
42597
Labour Cost for Roof RCC work
3348
1875
2882
2706
type of brick
8582
Last answer on 12/25/2013 2:07:19 PM. by S L Gupta (Civil Engg). Forum started by arunkrishna kannambadi
6035
Last answer on 10/18/2014 4:08:18 AM. by JAI PRAKASH. Forum started by bhatu
What is acre
Iron
Iron Sheet Roofing
