Home -> Forums -> Construction -> Layout and House Plans -> Construction Cost at Santhoshpuram (Near Medavakkam)
Mon Jun 20, 2011Total posts : 3
Sivaraj
Sivaraj
Topic: Construction Cost at Santhoshpuram (Near Medavakkam)
ssssss
I am planning to build a house in the sub-urban area of Chennai (In Santoshpuram near Medavakkam) about 1400sq ft area (GF 700sq.ft + 1F 700sq.ft). What is the prevailing construction cost in Santoshpuram?.
Whether the rates indicated by builders normally include the borewell, sump, staircase, OH Tank, compound wall, ?
Whether the construction cost for first floor, is normally less than Ground Floor?
What are the items that should be negotiated with the builder before commencement of construction. Is the staircase left open, costs the same as the roofed staircase? How the rates of staircase is arrived? Whether the area in the GF and 1F both is taken into account or simply the GF occupying area?
I am in need of it and no other way.
Advance thanks to all of you for the answers.
Tue Jun 21, 2011Post  #1
Post subject: Detailed construction cost estimate service fro...
Dear Mr. Sivaraj,
We have service for the construction cost estimate which would give you the brick by brick cost calculation.  Our detailed cost estimate pricing is given below:
Up to 2000 sq.ft area= Rs.2.50 per sq.ft.
From 2001 to 5000 sq.ft area= Rs.2.00 per sq.ft.
From 5001 to 10000 sq.ft area= Rs.1.50 per sq.ft.
Above 10000 sq.ft area= Rs.1.00 per sq.ft.
We will take almost 15 business days to prepare the detailed cost estimate.
We will supply you the document containing step by step calculation of the material and labor required to complete a construction project. This document is prepared after analyzing the architectural plan of the building and has all details about the cost and material involved.
We have the prices for all the building materials/ contractors/ labor charges from all over India, So we would incorporate prices as per your city.
Everyone can save upto 10% of the construction cost which can be a saving of Rs. 50 to Rs.100 per square feet.
For preparing the detailed cost estimate, We need additional documents from you:
3. Which type of shutters and wood is being used for doors and windows? Would it be deodar wood, hollock wood, teak wood etc.
6. Do you have exterior elevation design and structural drawings provided by your architect?
7. Please supply floor plans.
GharExpert can provide you a detailed cost analysis for your project that will help you save a lot of money.
A sample file for the estimate is available below.
http://www.gharexpert.com/include/sample_estimate.pdf
Send us the required information so that we can start preparing the estimate.
Gunjan
Tue Jun 21, 2011Post  #2
ramu771964
ramu771964
Post subject: House construction cost - approximate
Mr. Shivraj,
I had duly finished my construction at Vizag (Andhra)
It comes to around Rs.1000/- to Rs.1100/- per SFT. for construction for House using Normal wood doors / windows ,Vertified Tile flooring with one coat of paint.
False ceiling & Inside cubboards will be extra - carpentry items depending up on cost varies on the quality of material of wood items and area coverage.Outside balcony, boundry wall additional items , These all will be approx. Rs.200/-
Tue Jun 21, 2011Post  #3
Chakkara
Chakkara
Post subject: Project Cost
Dear Mr. Shivraj,
The construction cost from genuine Builders will comes around Rs. 1350/- Sft as on today and apart from this you must add 20% for approx 1500 Sft. of Buildup area for the Bore well, Septic Tank, UG Sump, Over Head Tank, Compound wall, Gate, Plinth production pavers, EB Temp and Permanent connections, etc.,
You must approach a good  Engineers for the detailed Specification, Cost and for a good builder.
Chakkara
7411
750 Sqft Construction
3384
what will be construction cost for a bunglaw at khandala, near lonavala
Last answer on 4/27/2016 3:10:29 PM. by S L Gupta (Civil Engg). Forum started by vaid
6099
What is construction cost
6464
4807
2681
2353
10179
1977
Supervision cost
2536
1479
1784
2746
23866
15130
does a home near temple is good?
Last answer on 10/8/2010 8:01:10 PM. by G N Shaikh. Forum started by sonal
3546
nice one some showpiece items should also been shown in almirah near by
Last answer on 12/31/2020 2:33:40 AM. Forum started by yuvi hada
2439
reference about the distance needed for house from near by temple and height res
Last answer on 6/18/2021 11:18:23 PM. Forum started by George Cherian K
1494
My son room can be in South East near kitchen areas
Last answer on 1/31/2018 12:40:32 AM. by S L Gupta (Civil Engg). Forum started by Prem
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2242
3595
2324
2090
2792
1548
2114
