Home -> Forums -> Construction -> Start Construction -> Construction Cost
Construction Cost
Sun Nov 18, 2012Total posts : 3
srivatsa
srivatsa
Topic: Construction Cost
Hello All,
I have recently purchased a new property with an area of 3300 (55*60) sq feet in Bangalore. The total construction area would be around 2400 sq per floor( leaving all set backs).
My idea is to build Ground and First Floor
  1. Cellar/basement for car park.
  2. Ground floor with 2 Bed Rooms
  3. 1st Floor with 3 Bed Rooms.
Flooring would be White Marble and all standard fittings ( not too low and not too hi-fii)
Requesting you to kindly let me know the approx cost for construction.
Srivatsa
Tue Apr 03, 2018Post  #1
            The construction cost varies with the specifications used in construction. This is from Rs 1200-00 to 1500-00 per sft.
Fri Sep 11, 2020Post  #2
So, by above thumb rule Approx Cost of Construction of Medium Specification = 1000 * 900 = Rs. 9,00,000 Where, 1000 is built up area and 900 is As per thumb rule assumed value. Further more to get an approximate estimate of various quantities required for 1000 sq. ft.
Sun Oct 04, 2020Post  #3
Dilip
Dilip
Post subject: i want to construct house, what is cost with mat...
hello,
my house is in Ahmedabad location.
i want demolise existing old house and  construct new house, what is cost with material & labour and with only labour.
my plot area is 28'x19' = 532 sqft.
Thanks & Regards
Dilip
6099
What is construction cost
4807
2680
2353
1783
2745
2122
2434
2196
2975
7411
750 Sqft Construction
1905
Last answer on 10/7/2020 10:22:43 PM. by S L Gupta (Civil Engg). Forum started by siva
2557
3597
6035
Last answer on 10/18/2014 4:08:18 AM. by JAI PRAKASH. Forum started by bhatu
2799
does any body have construction cost estimation free software?
Last answer on 7/13/2012 4:04:59 PM. Forum started by rajeev
Pl. give the construction cost of enclose plan
Last answer on 10/3/2012 3:33:55 PM. by S L Gupta (Civil Engg). Forum started by ami
3457
I want do construct a home, plot size (20x50)feet.What is the construction cost
Last answer on 3/25/2016 3:05:19 PM. by S L Gupta (Civil Engg). Forum started by Santosh Singh Bhadoria
3310
