Home -> Forums -> Construction -> Start Construction -> Construction of First floor- approximate cost of super structure
Mon Nov 26, 2012Total posts : 3
Biswajit Chakraborty
Topic: Construction of First floor- approximate cost of super structure
Dear sir,
I am going to start constuction of first floor of building with approx 2000 sqmt
built up area.The building is planned for upto 3 storied.in salt lake city,kolkata
What would be approx cost per sq ft with following
1. Rcc pillars upto 10 ft high
2. Rcc slabwith beams
3. 10" Brick wall all around with plastering and Birla Putty interiors
4. staircase upto roof with Mumty with Asbestos sheet
5. Aluminium sliding windows
6  Wooden Door with door frames
7. Vitrified tiles on floor with tiles in toilets and kitchen
8. Necessary waste water pipe connection to sewerage
9. Concealed water pipe connections in toilets and kitchen(3 toilets + 1 kitchen)
10.Concealed electric pipe systems with wire
Shall be pleased to get approximate cost per sq ft as thumb practice.
Salt Lake,Kolkata
Tue Nov 27, 2012Post  #1
Biman
Biman
Post subject: approximate cost of super structure
Dear Mr. Chakra borty,
Your post is not clear; either you have confused between units! And we presume you would construct, the first floor of a newly build single story house designed for 3 story structure. As salt lake belongs to upmarket neighborhood in Kolkata and considering higher cost of labour and supplies it would be between Rs.975 and 1350 psft respectively for minimal finish to a moderate MIG type finish. MF is 10.764 for sqmt. Rule of thumb you can adopt only for budgeting purpose, a detailed BOQ by an expert is needed to get the correct cost involved.
Reg,
Wed Nov 28, 2012Post  #2
Post subject: Approximate cost of super structure with interio...
Thank you very much for your promp reply.
I am sorry, the area will be approx 200 sq mt.
I could not understand MF = 1O.764,  Pl.explain
I have mentioned the necessary information regarding finish and requisites.Shall be pleased to get an estimation in a narrow band.
Mon Dec 10, 2012Post  #3
Dear Biswajit
For an estimate to find the cost, There are two ways one is detail estimate in which the estimate is framed on the basis of plan of the house, elevation and specification used in construction of the house.
The other method is tentative cost i.e. rough cost estimate. for calculation of cost by this method you can use gharexpert.com ESTIMATOR in this mehod place area and specifation and you got the cost.
7066
Cost of stilt floor construction
Last answer on 10/1/2009 3:08:55 PM. Forum started by Amar
5076
2582
JOINERY WORKS
3530
Contruction Tool
2713
Cost of RCC
Last answer on 4/4/2014 2:22:58 PM. by S L Gupta (Civil Engg). Forum started by Vasanth
6445
1459
2652
sir i want to know that what would be the cost total consturction of 2200 sq.ft
Last answer on 2/15/2022 11:12:49 PM. by JAI PRAKASH. Forum started by shruti Adarsh
15352
2nd floor construction
2635
2258
Cement selection
2805
Super Structure construction
Last answer on 9/25/2020 4:33:02 AM. by S L Gupta (Civil Engg). Forum started by aryan
2678
can any one tell me abt bamboo flooring .their cost and durability
Last answer on 1/6/2022 2:56:27 AM. by Swati Satija. Forum started by padmaraju
3135
Last answer on 7/3/2020 9:54:13 PM. by S L Gupta (Civil Engg). Forum started by padmaraju
6114
Last answer on 10/5/2021 3:01:31 AM. by Alexander Graf. Forum started by ravi garg
2074
residential construction cost
Last answer on 7/16/2014 7:54:25 PM. by JAI PRAKASH. Forum started by bharat patel
3515
Construction Cost
Last answer on 7/4/2020 12:13:03 AM. by nirmal. Forum started by Balraj
2607
COLUMN nd LOAD BEARING
2978
House Estimation Breakdown
2451
3274
3285
4430
3976
2201
2702
4212
5170
2379
2295
1997
2449
2115
3195
2048
12517
2164
2727
Earthquake
Sewerage
Sewerage & Plumbing System
Termite Control
